Maestro Function Keys
Just wondering. On the computer, I can leave the Multi-Flex dashboard on the screen to switch
the PTT from the Maestro to the computer. Would it be possible to make, let's say, F6 on the
Maestro to switch the PTT to the Maestro. It could be designated along with the other menu
options and would not necessitate a 3 button push to switch the PTT.
Just an idea.
73, Jim N9VC
Just an idea.
73, Jim N9VC
Jim,
This is a great idea. I'll make sure it gets visibility in the next Alpha software release cycle.
Mack
W4AX
Alpha Team0 -
Sorry if I'm missing the obvious, but what is the function of the MF Dashboard? I can still trigger the PTT locally regardless of the setting and can seem to set independent MIC profiles. The only difference I can see is if the Maestro is not selected, I do not get an indication of the non-Maestro client transmitting. Selecting the Maestro does not seem to change the appearance of the SSDR client. I've only tried this on my LAN so unsure if the behavior is different on a WAN.0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
