How to protect SteppIR antenna when using Power Genius XL?
Warren Wegerer
I haven't received my Power Genius XL yet but while reading about the amp I developed this question/concern. Since SteppIR antennas can take a considerable amount of time to tune between significantly different bands the SteppIR controller can be configured to include a lockout relay that prevents an amp from keying while the antenna is tuning. SteppIR says DON'T transmit with an amp while the antenna is tuning. However, I understand the PGXL integrates to the 6000 series radios with only the Ethernet connection, and I don't see any sort of TX prevention input on the amp to interface with. Has anybody thought this out or found a solution already? I intend to position my 6400M and PGXL remotely at a mountain cabin so I won't be local to monitor the SteppIR tuning process. I'd like to protect myself from the occasional mental glitches that can happen. I imagine I could interface the SteppIR TX protection to the "TX Request Input" on the radio to inhibit all TX while tuning, but I'm unsure. I thought I'd ask the community in case others have already found a different and possibly better solution. Thanks in advance...
I have two StepIR antennas and you were exactly correct on the solution you send the signal from the SteppIR controller to the transmit inhibit Jack on the back of the flexradio0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
