SmartSDR Version 3 problem Mic versus iPhone inputs can not switch
mikeatthebeach .
Just got SSDR Version 3 for my Flex6600M And share with iPhone SDR iOs When I set my Local Shack 6600M On 20meters SSB and my IPhone On 17meters I can not Set the SDR iOS MIc to IPhone So when I transmit on 20meters with my 6600M It keys my Tx On my iPhone and Tx Audio goes out on 17meters Sounds like we have a major problem Tried both LAN and WaN same results !!! Something messed up in the ability to transmit MultiFlex between iPhone and 6600M With no control to set iPhone MIc setting to IPhone Sounds like real problem here in V3 Mike
Interesting. I had my 6600M set up on 40m with 2 slices, one DIGU, one LSB. I connected my iPad, on 20m USB, and had no difficulty setting the MIC to “iPad”. Using a third slice.0
When I try to Transmit on 17meters SSB On the 6600M theTx on the indicator on The Flex6600M says iPhone and my iPhone On WAN vis Cellular transmits on 17meters A mess ! Mike0
I did not attempt to transmit, so have no idea whether the TX on Slice was working properly or not :-(0
You must make sure that the two clients are on different Mic Profiles - this will allow you to set different mic inputs for each client. This can be changed in the right menu of SmartSDR for iOS (https://manuals.roskosch.de/smartsdr-ios/#right-menu) and in the Profiles submenu for on the front panel of the M Model.0
Ted Apparently in order for this to Work work you must set the IPhone to Slice B while the Default for the 6600M is On Slice A Seems SDR iOS is not Smart To know that Slice A is already In use, resulting in both SDR iOS Being both on Slice A for Transmit So the Default for the Flex6600 Tx Audio and Transmit is Slice A When bringing up the iPhone it Also comes up as default A and One must change this to Slice B Once this is done, one can set The MIC setting on the iPhone To iPhone and then things work Properly If one does not set to Slice B on The iPhone, then the MIC on the Flex6600M key up the iPhone and Tx and Audio go out on the iPhone Frequency Guess it is a learning experience Software does not automatically Select to Slice B on the iPhone Maybe there a reason for that For maybe Multi-Op for 2 operators to go out on same frequency Thing we understand their logic now 73 Mike0
You also need to make sure you have upgraded SmartSDR for iOS to the latest version. ( V3.0.1 available in the Apple AppStore)0
Yes ,did that Ed, it upgraded on the iPhone Mike0
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 879 Genius Products
- 317 Tuner Genius XL
- 116 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
