NO RECEIVE ON 6500
SITTERLEY
Member ✭
The receive on my 6500 is nearly nonexistent when I boot it ir change bands. To get it back I have to switch the ant from ANT 1 to XVTR then back to ANT 1 then it is fine till I change bands again or re boot. However the transmitter always has output.
have you tried a Hard reset?
1st Export your profiles to some where like your desktop.
2nd Do a HARD Reset (look in the 6500 Manual)
3rd After the hard Reset then check to see if it works correctly, boot up frequency should be like 14.100 if I remember right if the hard reset worked.
4th Import your saved Profile, MAKE SURE you have the "Preferences" checked OFF, then import the Profile.
See if it still works If not you may want to do a support ticket.
73's
Bret
WX7Y
First step for diagnosis... Export your profiles, then do a factory persistence reset. (Hold the OK button while powering the rig on) Then see if anything has changed. Ken - NM9P0
Bret typed faster.......0
Reset didn't change anything
Bob K7POF0 -
Do a help desk ticket maybe Flex can help you out
Yep, that is the next step.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
