Using Bluetooth Earbuds with SSDR iOS ?
W2ECK
Trying to get my Bluetooth earbuds working with SSDR iOS 2.9.5:0.52 D1.41 and my Flex 6600. I was able to hear audio by going to the Audio tab, and turning on the “Listen Only Switch” , but then am not able to transmit obviously. Looked at some older posts on subject in the archives, but they don’t seem to apply to this version. So my question is how can I use Bluetooth earbuds and still have the transmit function available ?? And hopefully also use the earbuds built in mic? 73 Paul W2ECK
I am using Apple Air Pods on my iPhone with the exact same version of SSDR iOS and they work fine for TX and RX.
Hi Paul, I am not a Apple guy but I do use my iPhone 10xs with your exact setup. To get mine to work, I set up my ear buds to work making both standard cell phone calls and Skype calls. After that all worked, and no it was not obvious all the settings but the Apple store new all the tricks, then SDR played perfectly. Maybe that can help you get you working as well. Regards, mark0
What controls, features do you turn on or off to get ur Bluetooth earbuds to work? Pail w2eck0
Under the microphone pull down on my phone running SSDR iOS, there is an iPhone selection. This is what I choose.0
Where do u find the microphone pull down ?
Thanks to others for responses, but so far no change - still not able to get to work other then the LISTEN Only option
Paul
Hi Paul, please see attached photo0
I tried mine (PC) but there was a delay so I don't use them (V2.3.9). How do remove the latency?0
I had some early version ear buds as well as BT speakers that wouldn't work properly with the iPad on SmartSDR. They would play tunes fine.. I ended up with some newer versions later and those came up and worked fine. I haven't tried them recently but if I get a chance I will and verify the models and whether they work on my iphone 8 also. I remember Marcus saying there were some incompatabilities with some BT devices back along. Mike
Finally got the Bluetooth earbuds working with SSDR iOS on my iPad. Thanks to suggestion from John wa8clt, I uninstalled the version I had installed on iPad and then downloaded the newest version, then did an update. That got audio working on earbuds. Then after playing around with various settings on the MIC pull down button, settled on iPad selection, finally got the mic working on earbuds and successful T’ xing. So thanks to all who responded for the help. Now onto trying to get Smartlink working on iPad- so far no joy there. 73 Paul W2ECK0
- 335 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 171 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 733 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
