There are currently no radios available Flex 6400
Rui
-Pc Desktop - No Wifi Only Ethernet
Desktop using ethernet port --> router
Router Wireless
Any help? Thanks
Router Wireless
Any help? Thanks
A bit thin on information. Information you need to provide in order to get help: - How is your PC connected (you did answer that one - wired to the router) - How is your radio connected? To what? - You say no WiFi, yet say your router is wireless. - How have you configured your radio? - What type of router are you using? What software does it run? How is it connected to the world and to your network? Please give us a way to help you.1
Make sure you have a known to be good Ethernet cable, run it direct from radio to the computer, preferably after you make sure the drivers for your Ethernet on the computer are up to date. When you get it going there, then try running same Ethernet cable from radio to the router, if it won't work to there, there are some parameters in the router needing some work. Just a starter.
The Maestro has trouble if there are too many wifi signals, it was recommended I use 5GHz if available. Try moving the Maestro a bit to improve wifi reception.1
Rui - It sounds like what you might need is an Ethernet Switch, for example a Netgear GS108. Plug your incoming Ethernet Cable, and your PC, and your 6400 into the Switch to share your Ethernet connection.
- 636 The Flea Market
- 142 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
