power genius IMD at 2000w
Howard
Howard Member
power genius is rated 2kw output so therefore I would like to know the 3rd and 5th order imd at the 2kw level? What current and voltage does the power supply provide at 2kw output? my estimate is 80 amps (at 52v) will be the minimum requirement for a full 2kw out... anxious to hear the results.. 73 VE2AED Howard
  • Bill W2PKY
    Bill W2PKY Member ✭✭
    edited February 2019
    20M into perfect load 60 amps @ 47V = 1800 out.
    Not able to measure IMD.
  • Matt (K0KB)
    Matt (K0KB) Member ✭✭
    15M perfect load: 56A at 50V for 2kw power out
    80M perfect load: 56.3A at 51.9V for 2kw power out.
    These are steady carrier (tune function on 6600).
    Also not able to measure imd The amp is such a champ.
  • KF4HR
    KF4HR Member ✭✭
    edited March 2019
    Just curious.  Does the PG-XL auto limit itself to 1500 watts?
  • Matt (K0KB)
    No
  • KC2QMA_John
    KC2QMA_John Member ✭✭
    Sure is nice to have the extra headroom for a very clean signal.
  • Bill W2PKY
    20M 1750; 160M 1650 limit all others 2K. They call it automatic power control. APC The amp has protection monitoring against overdrive and SWR conditions.
  • KF4HR
    KF4HR Member ✭✭
    Nice.
  • Howard
    Howard Member
    edited March 2019
    John , How do you know that the signal is very clean ? Have you tried a 2 or 3 tone IMD test? Howard VE2AED
  • Howard
    Howard Member
    edited March 2019
    I have heard that the "Power Genius " does not have any antenna tuner , I wonder if I missed this detail . I am attaching a link to an IEEE paper "Output Impedance Mismatch Effects on the Linearity Performance of Digitally Predistorted Power Amplifiers " The paper also covers non predistorted amplifiers and the short story is that any impedance mismatch to the load can degrade linearity simply by the magnitude and phase of the reflected power .  73 de VE2AED link https://www.researchgate.net/publication/270788754_Output_Impedance_Mismatch_Effects_on_the_Linearity_Performance_of_Digitally_Predistorted_Power_Amplifiers
  • Bill W2PKY
    edited June 2019
    The External Tuner is in development, no ETA as of yet.
  • Burt Fisher
    Burt Fisher Member ✭✭
    edited March 2019
    How long has it been in "development?"
  • Howard
    Howard Member
    edited March 2019
    The tuner should be an integral part of the amp ,it can never be an option  the amp will be too distorted with "any" standing waves depending on the phase angle of the reflected wave regardless of what the SWR is ! So as I now understand financial budget is now related to non linearity of ~10Db .
    VE2AED
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited March 2019
    It will be an integral part of the amp. Flex makes outstanding products,,why would this be any different?
  • Howard
    Howard Member
    edited March 2019
    Bill , it appears that Flex has already begun shipping and as this paper trail indicates this is to be an "external" tuner and is still in development ,thus it appears that the amp will be shipped and the tuner becomes an external option . Thank you es 73 Howard VE2AED
  • HCampbell  WB4IVF
    HCampbell WB4IVF Member ✭✭
    edited March 2019
    The tuner has always been advertised as an external option!  Last I heard, it should be well-integrated with Flex (as Bill stated), and will be offered with an optional remote kit to allow installation at the antenna if so desired.  That would be a great feature in some installations and was one of the reasons given for opting for an external tuner.
    To me the main issue is the long, long wait, which is giving my ATR-30 a new lease on life.  (-:
    BTW, no amp that I am aware of has an internal tuner capable of a truly wide matching range at high power.  For that I’d look at an HF-Auto or similar.
    Howard/WB4IVF
  • Howard
    Howard Member
    edited April 2019
    Howard (2 ) this is Howard (1) there are 2 ldmos amps that I know of that have full power tuners , I have one of each so far KPA1500 and RFkit .
     Both can tune a full 3:1 in both directions ( 17 - 150Ω ) at 2KW although I don't recommend 2KW , I measure IMD with 2 tone ~ -35Db  at 1.5KW
    Howard (1) VE2AED  https://www.qrz.com/lookup/ve2aed
  • HCampbell  WB4IVF
    edited April 2019
    Hi Howard1 –
    Yes, the internal KPA and external Flex tuners should be capable of handling full power, but at a quite limited 3:1 matching range (the advertised Flex tuner spec is also 2000W @ 3:1 SWR).
    As I said, the physically separate Flex tuner can be placed at the amp, or as Flex has stated, at the antenna with an optional remote kit.  In addition to being closely integrated with the Flex radios/amp, to me that is an important feature and I may well take advantage of it.  Some prefer to have the tuner in the same box as the amp, and I can understand that too, but I prefer a separate tuner for the above reason.
    For any of these amps, if a wide matching range at high power is required you’d need a heftier external tuner.  I have not seen any published IMD specs / test results for the Flex amp as of yet.
    Howard2
  • Howard
    Howard Member
    edited April 2019
    Howard (2) ,
      I hope they test 3rd order  IMD into  15 meter multiples of coax into an antenna with 2:1 SWR and without the antenna tuner ... :)  "on 20 meters"
