SmartSDR v3.3.32 and the SmartSDR v3.3.32 Release Notes | SmartSDR v2.7.6 and the SmartSDR v2.7.6 Release Notes
Power Genius XL Utility v3.6.24 and the Power Genius XL Release Notes v3.6.24
Tuner Genius XL Utility v1.1.8 and the Tuner Genius XL Release Notes v1.1.8
problem when starting the flex 6700
on5po
problem when starting the flex 6700, it is missing, the window with the frecance, mode etc, without that impossible to conect HRD
to be able to make the window open, I have to activate a profile, after everything works
I had a 6300, 6500, never had this problem, never used profiles
who can tell me why this problem, can I forget to check something, or it is exclusively with the series 6700
thank you for explaining
Click on the +RX tab?0
I think you are referring to the frequency flag and vertical tuning bar. Try clicking somewhere in the center of the screen (grid). A frequency flag should appear.
I think your preferences have become corrupted. Please try this:
Export all your profiles, perform a hardware reset on the radio, and then reimport your profiles but UNCHECK preferences.
Perform a hardware radio reset. https://helpdesk.flexradio.com/hc/en-us/articles/360020078612-How-to-Completely-Reset-a-FLEX-6000
Import your profiles but UNCHECK import preferences
This should fix it. Sounds like something is corrupted.
Mack
W4AX
Alpha Team
bonjour Bill, merci ça marche, ma question, pourquoi dois-je cliquer sur "RX" à chaque fois,
cela devrait être automatique, à chaque ouverture du flex comme sur mes précédents 6300 et 6500
pour info à d’autres réponses, j’ai déjà réinitialisé , Il y a 15 jours en raison d'un manque de mémoire en clôture, "Tim" m'a demandé de le faire, maintenant j'ai ce problème (mineur) Je vais suivre la recommandation de Mack et réinitialiser à nouveau et vérifier, si "les préférences sont bien désélectionnées
Merci à tous
hello Bill, thanks it works, my question, why do I have to click on "RX" every time,
this should be automatic, at each opening of the flex as on my previous 6300 and 6500
for info to other answers, I already reset, 15 days ago due to a lack of memory in closing, "Tim" asked me to do it, now I have this problem (minor) I will follow Mack's recommendation and reset again and check, if "preferences are well deselected
Thank you all
for information, I just tried the "RX", DM780 does not work, no watherfall, I have to use a profile
sorry for the french version
Hello Mack,
I just followed your reset instructions, it seems to work properly
thank you 73
Great! I'm so pleased it worked for you.
Mack
W4AX
Alpha Team0
- 18.5K All Categories
- 132 Community Topics
- 2K New Ideas
- 279 The Flea Market
- 6.2K Software
- 5.4K SmartSDR for Windows
- 93 SmartSDR for Maestro and M models
- 211 SmartSDR for Mac
- 188 SmartSDR for iOS
- 180 SmartSDR CAT
- 113 DAX
- 321 SmartSDR API
- 7.8K Radios and Accessories
- 6.4K FLEX-6000 Signature Series
- 630 Maestro
- 29 FlexControl
- 777 FLEX Series (Legacy) Radios
- 408 Genius Products
- 240 Power Genius XL Amplifier
- 145 Tuner Genius XL
- 23 Antenna Genius
- 119 Shack Infrastructure
- 75 Networking
- 204 Remote Operation (SmartLink)
- 91 Contesting
- 306 Peripherals & Station Integration
- 87 Amateur Radio Interests
- 580 Third-Party Software
