Whats the logic for using DIGU instead of USB for FT8. If you use usb with a 4K filter you can see t
N4AB
Whats the logic for using DIGU instead of USB for FT8. If you use usb with a 4K filter you can see the whole band and jump any where to transmit.
73 Al, N4AB
73 Al, N4AB
DIGU removes any transmit audio processing or shaping, providing a nice clean, flat response for your digital operation. In receive you can also use wider bandwidths - I use 5 kHz on HF.3
Can use wide bandwidth in digiu as well...0
I find the "wide graph" contained within the FT8 program to be much more useful in finding a free transmit frequency than attempting to use the SSDR screen.0
Another reason is that DIGIU turns off all processing0
Sorry, I didn’t see the earlier reply.0
I seem to remember someone (might have been steve) saying it also had lower latency.0
Al
DIGU / DIGL, and USB / LSB modes on a Flexradio, differ only in the fact that DIGU and DIGL modes bypass any, and all, DSP processing effects. You don't want any EQ-ing, or noise filtering being done on the signals your trying to decode. USB / LSB modes don't bypass those. Think of it as quick, convenient way to ensure that your sending unadulterated signals to the Digital Application your using. The choice is yours though, you can use USB / LSB and disable all the effects manually.73, Jay - NO5J
3 -
Brilliant question and good answers.
It was like asking one of those questions that one is afraid to ask
I always wondered what the difference was
Thanks Al
Paul1 -
Al
Also, the bandwidth filters are optimized for digital applications when using DIGU, they will either all use a 1500Hz center frequency or will be wide filters that start at 0 Hz and then go up to some useful upper cutoff point, like 3k or wider. Whereas USB filters are optimized for voice operations.73, Jay - NO5J
2
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
