Multi-Client?
Michael Coslo
Is it allowed to get some hints on how the Multi-Client setup will work?
Is this a setup that will allow 2 (or more) people to work remotely in a multi-Op class in a contest?
Same Frequency or double bands? Would this be considered Multi-Single, or Multi-Multi? Probably Multi-single since you can't transmit two signals at the same time.
How is this coordinated? I'm trying to envision all this, but I suspect what I'm thinking is wrong, because what I'm thinking of would be an exercise in frustration.
I wonder how much I can charge for FlexTime on FleaBay ?0
I have been testing 3.x but I cannot say anything really about it. I think once it is out lots of our "pro" ops will figure this stuff out and we will have a number of "how to" docs.
Mark0 -
Pity - As a long time contest chairman, I might have had some input. Oh well, I guess I'll know what it does after it's finished.0
My understanding, based on what has been said publicly, it will allow one 6000-series radio 'receiver' to host as many independent 'slices' as the server will support (2x for 6300/6400, 4x on 6500/6600, 8x on 6700), and any user can 'steal' the transmitter when needed. Only one user/slice can transmit at one time. On radios with Maestro front panels, which only support two simultaneous 'slices' natively, it will allow the additional slices on the 6600M to be accessed by another device while the front panel is in use.0
As I understand things, another person can be loged into your radio without you even knowing, other then when they transmit that person has no effect on your operation. They have there own radio and all the settings are theirs. If that guest is transmitting your screen will tell you the transmitter is in use. As soon as the light is out your free to transmit.
Either way, this is completly new technology in ham radio, it will be very interesting considering they will build on this V3.0 -
For those who haven’t seen the press release at https://www.flexradio.com/downloads/press-release-smartsdr-v3/ :
Page 2:
I’m hoping that somewhere in v3.x they’ll add the previously discussed “mirror” function that lets one user operate multiple clients (say SSDR and Maestro) simultaneously on the same frequency.
Howard
I wish, but from some previous discussions I don’t think the initial v3 release will allow a user work the same slice/frequency simultaneously with multiple clients (each tracking the other). That’s what I’d be most interested in – using the mouse in SSDR or knobs on Maestro, whichever I feel like using. A complex design I’m sure, but maybe feasible further down the line in v3.x …….. ?
Howard
ICOM will soon follow with multiclient.
Actually, using the Icom remote access software allows a second person to use the second receiver without interfering with the main.0
Right, but what some of us are looking for is the ability to share the functionality of two different devices (Maestro and SSDR) with a single client. I suspect that is a tough nut.
Keith - AC9S
Yes there will be others trying to catch up with Flex, give them time and they just may.0
This should not be a pissing match between Flex and the others. Flex has its own merits. The Icom built in internet server allows you to keep all clients in sync. Push a button on the screen and the light on the radio changes. Ditto for all other controls. With respect to the second radio, when you use the remote client you chose if you want to use receiver 1, 2, or both. Pretty simple.0
ZenkI,, what things do you like most about your Flex radio?0
Pretty good receiver, paired with built-in SO2R capabilities, laying a good foundation for a simple station. The transmitter, however, can certainly benefit from pre-distortion. I don’t use SL so can’t comment.0
All radios can benefit from Pure Signal, But most Flexes go down as low as 40db, my 6500 does. For this reason most of us do not feel Pure Signal is so important.0
Bill, ZINKI, if he's the same person on qth.com, is very much into transmitter IMD, and the benefits of Predistortion for spectrum purity. I agree with most of his thoughts on this, but I doubt that FRS will implement it anytime soon, given the already low IMD numbers for Flex transmitters compared to others currently on the market.(besides Anan) James WD5GWY0
Ok, James. There was no mention that Icom does not have it either.
But as some have noticed, the PGXL addresses IMD in a different way with much the same results. The PGXL has a hamonic dummy load that takes the harmonics from the TX and turns that energy into heat. Leaving a very clean signal.1 -
Bill, the PGXL would be a very expensive solution to transmitter IMD for those of us not needing or wanting an amplifier. :-)1
Lol,, very true indeed.0
Oh, and if I remember correctly, the 6000 Series already has the needed hardware connections internally. It only needs the firmware recoded to implement it. ( probably take some time to test)0
Correct, James. Gerald has alway said he wants to implement this in a Flex kind of way. But, would we want this before they re visit the RX filters? NB, NR and so on? And it is easy to understand why multi client is soon coming shoving those things further back.0
I think multiflex became a pressing issue when people with "6600M" radios had to choose between two slices on a maestro/front panel or all 4 available slices on a PC running SSDR. That "either/or" choice probably cut into 6600M sales, I guess.0
Ken, for me it was an easy choice to trade up from my 6500 and Maestro to the 6600M. I like having an all in one radio (knobs and front display). And still can use SSDR if I want access to all four panadapters if I want. I think when milti-client comes along, and FRS allows SSDR or my app(once it's ben updated) to use 2 or three panadapters on my big monitor, I'll be in hog heaven! Bill, given that Flex's transmitters are already very clean , I would rather have the functions you mentioned, receive the attention from FRS that I and others feel they need. But, from a revenue standpoint, I can understand why FRS felt the need to get v3.x out sooner than later. And to reiterate, I would be hard pressed to want to get rid of my 6600M over something like the ANF. James0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
