Welcome to the FlexRadio Community!  Please review the new Community Rules and other important new Community information on the Message Board.
What type of Amp are you using??
            SPE Expert 1.3K FA It does use CAT to interface.0
            Tokyo Hy Power HL-2.5Kfx. Would like to have it CAT controlled, but thus far have not been able to get it to work: https://community.flexradio.com/flexradio/topics/troubleshooting-flex-6500-band-following-with-tokyo...0
            SPE Expert 1K-FA - CAT controlled using two USB Serial cables from the 6700. Fully automatic!0
            Prometheus DX2400L1 amp controlled using USB/CAT converter cable control from 6600 & 6700. PGXL ordered early-on in 2017.
            Still running my Alpha 87a , could use ban data to have me follow, but auto frequency sense works very well. Dudley WA5QPZ1
            Collins 30L-1, No such thing as CAT when it was designed. Soon to be hooking up a Collins 30S-1, Same issues, but More Power!0
            Running the 6600 with an Acom 1000. No cat. Microprocessor asisted manual tune is quick and easy. It is also 1k output on 6 meters.0
            did you check RF-Kit.de and the legal limit B26-PA? Full remote via LAN or cat interface ! Direct USB connected to any F6xxx = no PC needed.
See also : https://goo.gl/FWWHXU0 -
            Hi, I use 2 x OM2500A cat controlled. Remotely controlled in SO2R over internet LAN. The OM2500A runs on 2 x 230 V transformers which is nice with a "poor" rural area line voltage supply capacity (only 10A per phase). For back up two manual Henry 3KD w 3CX1200D7 continous 1 kW 1.8 all through 30 MHz. What masterpieces.
            Expert 1K-FA CAT control from PC
Tim0 -
            Flex 7600 Acom 1200S and AT-04. CAT worked fine with 1200S but will not work since AT04 added. Flex does not appear to recognise commands from 1200S?
Dave. G3SBP0 -
            Ameritron AL-572, not CAT control capable.0
            B26 RF-2K+ with CAT control, and an Elecraft KPA-500/KAT-500 using DDUTIL.
73 de W4EEY
            Ameritron ALS-1306, USB/CAT controlled.
            W6PQL Kit whit custom controller for specific remote operation
use FTDI USB cable to BCD since it daisy chain-able to all amp on the rack
but "master" controller listen amp monitoring RS-485 bus for set radio power trough CAT command
for now it have
1250W for HF+6 / 144 / 220
432 500W
1296 600W
2304 300W
VE2PN0 -
            KPA500/KAT500 w/6500/6600. I use CAT. Perfect integration like it was designed for Flex.
AL, K0VM
            Here's to inverse snob appeal! SB 220 with full bio control.3
            Hi david - Yes I did! It didn't work for me though. Maybe there's a problem with my amp but since I don't use it much I just band switch manually.0
            Icom PW-1 using DDUtil software for Auto band switching and drive power per band only.
            6600M. CAT to SPE Expert 1k-fa with a cable made by KC5PCB for Expert Linears America. Works well.
            Using Alpha 87A driven with 6600 and cat controlled with DDutil for band and other amp functions. Works great.0
            SPR Expert FT-1A, 1000 w., CAT controlled.0
            Bill - Can you share how you have them all connected? I currently have the same setup, but not the KAT-500 which I'm thinking of purchasing. Thanks.0
            Flex 6500, Acom 600s and Acom ATU 04AT, cat, full integration not achieved (fully automated turning from Acom Amp) but hopeful of updates from Flex V3? and Acom after requests were made.
Mark M0MTA
            Eric SM0JCA has got ACOM 1200 s working very well with his new FLEX-6400M. He has been talking with the ACOM factory and done great. He is on the forum here as well0
- Elecraft KPA-500
 - RS232 (XCVR) port on KPA-500 --> Flex 6600 USB for CAT info
 - RS232 (PC) port on KPA-500 --> PC USB to serial connector
 - DDUtil for a) adjusting power output of the 6600M by band. b) Turning amp on/off
            I'm running a Palstar LA-1K with a IC-7610 and an HF-AUTO tuner. It is CAT controlled.
My Flex 6400 isn't currently connected to an amp, though I have an SB-221 with the 10m mod that I could put on it.0 -
            Ten Ten Titan Gold series. No cat
            Collins 30S-10
 - 361 Community Topics
 - 620 The Flea Market
 - 8K Software
 - 32 SmartSDR+
 - 6.3K SmartSDR for Windows
 - 415 SmartSDR for Mac
 - 267 SmartSDR for iOS
 - 252 SmartSDR CAT
 - 188 DAX
 - 378 SmartSDR API
 - 9.2K Radios and Accessories
 - 27 Aurora
 - 928 Maestro
 - 902 Genius Products
 - 325 Tuner Genius XL
 - 118 Antenna Genius
 - 288 Shack Infrastructure
 - 202 Networking
 - 141 Contesting
 - 982 Third-Party Software
