What type of Amp are you using??
Using an SPE 2K-FA CAT- controlled. Best amp I've ever owned
and an older Alpha 87A also CAT-controlled. Terrific key down rtty amp. But I don't like the 3 min. warm-up0 -
Elecraft power combo KPA500/KAT500 and DDUtil to get everything preselected and coordinated as I change freq/bands.
Kev K4VD0 -
i use KPA500 controlled by 6600m with usb cable
Paul K3SF
SPE 2K-FA. It is CAT controlled from the USB port on the Flex.0
Acom 600S Cat controlled
73, Jim N9VC
Is the KPA500 CAT controlled by the Flex or by a computer?0
SPE 1K-FA via CAT / SmartSDR USB Control Alpha 99 via knob turning PGXL on “Wish List” 73, Hunter K3IE0
Flex-6700 and Alpha 87A, Auto-Sense (not CAT controlled). Standing in line for a PG-XL.
SPE 1.3K with CAT control via USB to either the 6400 or 6500, depending on what I’m doing0
I am using an Expert 2K-FA amp with the Expert interface cable made for Flex radios. I use a Flex 6600. Plug and play.
Bill, N5IR0 -
I use the Expert 1.3K-FA amp with the 6500 and CAT control. It is great with FAST solid state operation. You're on the air with the amp in 10 seconds. I also use an Acom 2000A not CAT control used primarily for contesting.
2K-FA, no.0
I am using a Yaesu Quadra with CAT control.0
Home Station Flex-6700 or Flex-6600M with PGXL or Alpha-9500 Island Station Flex-6700 Alpha-9500 (waiting for a PGXL for the Island) Workshop Station Flex-6300 Alpha-78 (but usually run barefoot) 73 Steve K9ZW0
Ameritron AL-1500 with QSK-5. Wish PGXL had QSK!0
IC-2KL and AL811H I expect to get my PGXL call on the next February 29th.0
I'm using the FRS 6600M with the German B26 RF 2K+ Amp Kit, tuner included.
Tom W3FRG
What kind of CAT software you are using?0
145 pounds! I am not physically capable of moving an amp that heavy!
SPE 1.3KFA , homebrew cat cable....0
B26 RF2K+ / Palstar AT-AUTO / 403A Antenna Genius; all CAT controlled. Change bands and everything sets itself automagically. :-)
SPE 1.3K via CAT / SmartSDR USB Control...using a Flex 6500
Flex 6600 with Elecraft KPA1500.
CAT controlled, no special software required. Uses Elecraft USB cable for CAT input from back of Flex 6600 to KPA1500.
If you op CW, Full QSK, very fast, no TX Delay required, and no relays. 2800 watts of LDMOS devices. Internal auto tuner.
Tom
K3TF.....
Definitely not portable....put it in place and leave it there. My XYL and I set it up.....
Actually the power supply weighs 145 once the transformer and choke is installed. The RF deck is another 60 lbs and about 30 pounds of that is a copper heat sink.
No one is going to walk off with it, haha.
Al / NN4ZZ
al (at) nn4zz (dot) com
6700 & SSDR-W V 2.4.9
Win10
Acom 2000A
Sergey, KN7K0 -
Flex 6600M With KPA-500/KAT-500 using DDUtil's auto drive to set the drive levels per band,0
I have a 1.3k-fa and use the same cable. It is made by KC5PCB for Expert Linears America. I don't think it has a part number.
Paul W5PF0 -
KPA500/KAT500, CAT-conrtolled (once I get around to setting it up).0
Kenwood TL-922. I am the cat0
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
