Flex 6x00 and Micorham Station Master
Lorenzo Mendini
Hi, i have a question i need to connect my Flex 6300 at my station master made from microham, i have build the cable but i don't know how to set properly the software, anyone can send me some screenshot of his configuration.
Many thanks bye bye
Many thanks bye bye
ciao
the best approach to drive SM is by flex USB interface+(suggested) USB to Serial adpater
Ok Don, please call me as soon as possible, many thanks.
ok0
anyone can confirm that the followed wiring diagram are correct?
Pin # Label DescriptionTIP TXD CAT DATA output from SM
RING1 RXD CAT DATA input to SM
RING2 RTS +12V output, max.1mA. Connected to input power via 10K ohm resistor.
SLEEVE GND Connected to the system ground and case.
i don't undestand how to connect the RING2.. i need to put one resistor in the cable?
Hi Adriano,let me give you more details (the configuration that I have)
a) on flex/smartsdr configure a CAT cable (see smartsdr cable management section)
b) Station Master JUMPER SETUP : the RS 232 LEVEL is required (see manual extract and picture below)
b) the CAT connection cable from RS232 to Station master , see below
Nothing to do in microham router? Many thanks0
not clear to me, what do you mean for microham router ? what do you need to achieve ?0
Hi Don, Does your Station Master integrate 100 % OK with the Flexradio with the Yeasu CAT cable? 73 Kari SM0HRP0
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
