Shielded Ethernet Cable
Dave
Does anyone have any thoughts on the use of shielded Ethernet cables?
Highly recommended. I'm just switching over to them now -- just in case there's some RF floating around the shack. Also, make sure the cables are CAT6/6A.2
I replaced all my cat 5 cables with shielded cat 7 and a switch that also had metal grounded connectors. I verified continuity between radio and computer chassis. Since then, I find that my computer does not freeze up due to suspected extraneous rf as it did before. I tried to keep the runs as short as possible. I would highly recommend it.
Frank N5SSH
Always. I use nothing but CAT 6 or 7 shielded cables. My Ubuquiti Unifi switches are all PoE and in metal. Agree with Frank - use shortest cable possible.1
Makes all the difference at my very QRO commercial broadcast sites. Better data integrity all around.0
Hello Dave,
I’m planning to pull around 150 feet of Ethernet cabling in my condo building (from the roof to the club room) and was thinking about this too. I think most folks would have used Cat5e for home installs in the past but are moving to higher grade cable now — since I’m running such a long run through my building I’ve decided to use Cat7 shielded cable .
Here are some information links I have found helpful:
https://www.axis.com/files/whitepaper...
https://www.pcgamer.com/what-are-the-...
https://www.belden.com/blog/smart-bui...
This is the product I plan to purchase:
https://infinity-cable-products.com/p...
And a good conversation thread on Redit:
https://www.reddit.com/r/amateurradio...0 -
I used shielded in industrial applications...in fact it was a requirement..but they need a path to ground thus the receptacle is designed to ground the shield. I don’t believe most home devices are designed to ground a shield.0
Absolutely. I had RF messing with my network on 75 meters. My station is on the second floor and router on main floor. Pulled a new run of shielded, grounded at station end, and problem solved.1
I hate to be the contrarian here (well, I usually am) but I have seen where this can really cause problems. When I was working at Flex, we had a case where a customer could not successfully connect and get his radio registered because there was interference appearing on the shield and causing lousy service quality. It might be purely an issue of cable quality but its not necessarily a great idea.
I honestly think going optical is a much better solution to rf/noise plus it gives you the peace of mind that lightning charges will not traverse your lan (as it did for me 2 years ago and blew everything not only connected but near the cable).3 -
I recall Flex recommended against using shielded cables because of ground loops. I would like FRS to reply to this in case the situation has changed their mind over time.0
Very much agree. NN4ZZ has posted fiber optic configurations here. It is not
as expensive as you might think. I've been zapped twice by lightning. Some
suppressors were in place, but both times took out network cards. Radios and
routers were spared, however. With ethernet going everywhere and often to
some very costly equipment, fiber should be a serious consideration.
Ned, K1NJ
3 -
You can find Ethernet to Fiber Converter Pairs Rated 10/100 with Two power Supplies all for $19 to $22 on EBay Works great with my Flex6600M Lightning Protection dirt cheap No excuses not to do it These are Plug and Play just add A Fiber Cable and you on you way ! 73 Mike Search for this on eBay 1Pair 10/100M light RJ45 Ethernet to Fiber Optic Media Converter Singlemode 25KM2
Thanks for all the input... I thought of just going fiber, true isolation!!!! I did pick up some DX engineering ethernet isolation / supression devices....I think they are a newer product, they seem to have good reviews
Is this the kind of product at DX Engineering you mean? https://www.dxengineering.com/parts/dxe-iso-plus-21
That's what I plan on doing. I only need a 10/100/1000 media converter for upstairs,, a cable, a pair of sfp + transceivers and done. My router already has a sfp + port.1
Can't speak for every other issue in regards to shielded Ethernet cable, but it worked for me. With a legal limit amp on, I could make the laser clip on the node that serves my neighborhood. That's three quarters of a mile away. RF would make it all the way back to the modem and ride the hard line back to their converter. I almost couldn't believe it until the regional comcast supervisor showed me the spectrum display for the laser on his laptop. Could key up and see the spikes in real time.0
In the process, they found a few bad hardline connections they repaired also.0
;Yes that is what I ordered. Seem to have good reviews from the few I could find.. Was also talked about in Ham Nation https://twit.tv/shows/ham-nation/episodes/3860
Mike, are you seeing any birdies coming from the power supplies on those very inexpensive (<$20) Ethernet to fiber converters on eBay? At that price point, it hard to imagine how those wall warts are not RF emitters at some frequencies. I use fiber for the 100 foot run from network entry point to the shack and then Ethernet for the short runs around the shack. The DXEngineering devices look very promising where Ethernet is a requirement.
You can also pickup one or more HP Procurve 2524 24 port switches and if you look around you can get them with one or two Gigabit fiber links installed for less than $25. One of these with a media converter or two will give you fiber. I did my entire LAN with fiber for less than $100. The HP power supplies are clean. I also did not see any birdies on HF from the media converter supplies.
The one thing you should keep in mind is the HP switches are commerical grade and thus you might find the fan noise too high for a home desktop install. My Flex is in a unfinished room in the basement so noise is not a issue for me.
Ethernet switches with X/SFP sockets in them, plus the X/SFP modules themselves, are becoming very inexpensive. This is often a better choice than using a converter. Have a main switch for the house Ethernet, plug in an X/SFP for LC connector fibre, then run as much as you need to a smaller 4-or-8-port switch in your shack, also with X/SFP socket.3
I also use shielded with one note. Connect one end normally to your switch (metallic shield to metallic switch connection, BUT put a non shielded double female near the other end with a short jumper to finish the connection.
This will prevent ground loops yet still shield the cable.2 -
A double female connector is usually considered bad form, and should be avoided, especially if you are running long runs of cable or Gigabit speeds (or higher :-). Much better to simply use a non-grounding RJ45 connector on the radio end.0
On long runs like that, you might consider going fiber.
Jim, K6QE
Thanks Ted, I agree about the double female but that is the fastest way to unshield one end. My preference, when using pre-assembled cables is to get one that is long enough for making two cables, cut at a split point, then add a non-shielded connector to each.0
Wow thanks for the input everyone. Went to shielded ... Will probably use fiber at some point!
No birdies from what I can tell FYI, just ordered A pair of DXE Ethernet RFI Filters Know Fact to much Power on Tx Can play havoc on 75meters into Ethernet Cable On on the Flex 73 Mike0
Dave Did the same after Tx with QRO on 75meters Can drive the 6600m screen crazy here !!! Added a pair of DXE RFI Ethernet Filters to take care of this Mike0
Especially when your run of Ethernet cable is about a quarter wavelength on 75. LOL0
Got the DX Engineering Ethernet RFI Filters today My Noise Floor drop significantly on 6meters with pair between my 6600m and Router also a pair on my Ethernet to Fiber Media units clean up my Radio Well from carrier birdies Think most Birdies where From 6600m to Router, the Media Ethernet to Fiber Units were clean to begin with no birdies observed there Can use QRO on 75meters with no glitches No RFI affecting the Remote Station Would say adding the DX Engineering Ethernet Filters to the Station was money well spent ! Hope this helps someone out there ! 73 Mike1
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
