1W out with FLEX-1500 after update
Richard Gasparik
Hi all,
I update PowerSDR KE9NS v2.8.0 from build 80 to 113 and my FLEX-1500 is running 1W max instead of 5W. I don't know where is a problem...
Any idea?
Richard OK8WW
Any idea?
Richard OK8WW
Confirm that the drive and the tune is set at 100. The default tune drive sets at 10. I am presuming you are using the same power meter that you used before the upgrade.0
Yes, drive and tune is set to 100, using always he same power meter..0
funny, I came back to build 92 and it works...looks like a bug in the sw...0
Good stuff so the radio is 100%
If you send KE9NS an email he will respond pretty quickly. He has helped me before. Regards Gavin ZS6BG0 -
I'm sure he is on the list here...happy that the radio is OK
Rich, I own a Flex-1500, check your antenna selection, it may be set for a transverter. Just a thought.0
Are you selecting Tune button? Select Tune, then while the "Tun" is selected, then move the " Drive " control to 100 % . There is a normal operation and then a Tune selection WHILE selected only .. The default is 10% not 100% in Tune.
Dudley
WA5QPZ
I tested my 1500 running v2.8.0.113 with no issues (5 watts out to a dummy load).
As a test, do a Setup->Factory Defaults (this will make a backup of your current database to you desktop first). Or a SHIFT+CTRL+C and do a restore calibration from the EEPROM to your database and see if that fixes it? (with Tune reset back to 100)
Darrin ke9ns.com
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
