flex 3000 "winlink express" SCS PTCIIpro
Jack A. Speer
I am feeling frustrated trying to interface my Flex-3000 with "Winlink Express" software using a pactor SCS PTCIIpro. Winmor not of interest.
I have read and studied Flex information on the web repeatedly.
Any step by step help/procedures appreciated. 73, Jack, N1BIC
Make sure you lower your audio buffer sizes to reduce turnaround latency . This will increase you CPU usage through, try not to go over 60% cpu usage. Are you getting it to send OK, just not getting recognized by the responder? Dudley0
Please post your setup here:
- What kind of cable are you using between your PC and the SCS PTCIIpro?
- What are you using, a PC or a notebook?
- Your PC to PTC connector? RS232 direct or RS232 to USB adapter?
1. You'll need a good connection to the SCS RS232. Not all adapters work.
2. The audio /PTT cable between the SCS and the Flex3000 connects to the FlexWire. I built it myself.
3. On the Flex-3000 setup you must choose the FlexWire connector
Also please read this article: http://kc.flex-radio.com/KnowledgebaseArticle50422.aspx
Hope this helps.
Vy 73, Alex - DH2ID0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
