usb port can not turn on DEMI 2mldpa
AH0U
I have a new DEMI 2MLDPA set up as an amp...plugged into the 6700 USB port.. when I switch to 2 meters on the Flex, the unit does not turn on...I returned it to DEMI and they tested both the unit and cable and say it works per specs... I tried both USB ports with the same results... any ideas???? running 2.4.9.115 software on Windows Pro
This may be a **** question, but have you set the USB connector mode to LDPA in the SmartSDR Radio Setup menu?
Other than connecting dc power and plugging in the usb cable, this is all that is required to make the 2mldpa with remote option to work.
Yes in deed... one of the first things I checked right after measuring the voltage at the uniy0
Obviously there is something more... I think the unit has a wiring error but have no idea what DEMI tested when they certified it was “in spec”.... did they check to see if it turned on remotely??? Beats me... should be plug and play0
Call DEMI and have them walk you through it.
ttied that.... they don’t do that but did say everything was set correctly0
Did you ever get it working? I have a problem where I can get my LDPA to turn on with Smart SDR, but it will not with my Maestro.0
Yes... the power plug on the DEMI was faulty and did not make contact with the unit so when I measure voltage at the plug it was good but it did not connect inside the DENI0
- 337 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 18 Aurora
- 188 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
