DIY Automatic Remote Multi Transveter Interface for Single XVTR Port
Hello,
I thought I would share a project that I am working on to provide switching of multiple transverters from the single XVRT port on the 6400. I am sure there are simpler ways to do this such as using DPST relays for the RF switch. However, this seemed to be something I was more comfortable with and I already had the SaniSwitch relay. I found the Chinese DIY remote antenna switch kit on ebay and felt this would make a sensible combination and provide isolation for the rf inputs to the transverters. I will post the USB Cable settings from SmartSDR once I complete the project and fully test for proper operation. I will be using the inexpensive Transverter Store devices for this project.
Any comments or suggestions would be welcomed.
Don
KC5HCX
I meant to say SPDT relays, not DPST, oopps!!!0
Very cool Idea and it interest me quite a bit but your Pictures are pretty low res and blurry, can you send the pictures on google share or something maybe to wx7y@arrl.net that has better resolution.
Thanks so much and great Idea
Bret
WX7Y
WX7Y,
I sent a copy of my original file to your email as requested. I hope this helps.
KC5HCX
Very cool Idea and it interest me quite a bit but your Pictures are pretty low res and blurry, can you send the pictures on google share or something maybe to me wx7y@arrl.net that has better resolution.
Bret
WX7Y
This might be of interest to you:
https://www.w6pql.com/automatic_transverter_interface.htm
This unit does all of the above and automatically selects the transverter and no actual mechanical relays. I have already ordered the board (months ago but no time to finish it) and am finally putting the box together. Mine will be rack mounted. Maybe I will post pictures once done.
It can also be stacked, as in 2 sets which I am considering as I may pickup a 902 (33cm) transverter at some point as well as a 23cm one.
I use IF A for 630m experimenting, IF B for VHF transverters and Receive A for my AOR loop so pretty filled up! If you are active on VHF/UHF and like to have the waterfall on them, a switch is a must. Let us know how it goes.0 -
This project is complete and works as expected. If you have any interest you can see the final product and cable settings on my QRZ page.
https://www.qrz.com/db/KC5HCX
Don
KC5HCX
- 631 The Flea Market
- 123 SmartSDR+
- 195 DAX
- 39 Aurora
- 950 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
