VoiceKeyer
Bill English
Has anyone had any success getting the PTT to work on VoiceKeyer? I have never had any issues with PTT on my Flex rigs, but I can only get this program to work on VOX, since my wife has a very mouthy Jack Russell, I prefer PTT ;-)
Yes, use it all the time. Set up a PTT COM port in SmartSDR CAT and pick that port in VoiceKeyer.0
Hi Bill. I have it working with PTT. You need to set up a PTT Port in CAT and then use that COM Port in voice Keyer. See the 2 attachments
. Good luck and 73.
That is how mine is set and it doesn’t key the rig. When I press a memory button I see voicekeyer appear under the com port in CAT. The audio sounds great, but the only way I can play it on air is with VOX. There are no errors, it just doesn’t key the rig. I have N1MM running with WK emulation, MMTTY, WSJT, no problems at all. The radio will key with everything but this program. I appreciate your help! Bill K4FX0
Just build a "PTT" SmartSDR CAT port and point voice keyer to this port
73's
Bret
WX7Y0 -
That fixed it. Thanks Bret0
Hey all, which voicekeyer software are you all talking about here? Thanks0
- 372 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 997 Third-Party Software
