S Meter Plus
Does anybody have a current versio of Beppo's S Meter Plus?  Woodbox radio is long gone.
Welcome!
«1
  • Member ✭✭✭
    edited January 2019
    I have the woodbox smart s meter v16 if that does you any good.
  • Member ✭✭
    edited June 2019
    Larry,
    Yes, I have the original version but was hoping to upgrade.  Is it email-able? ed@w2ph.com
  • Member ✭✭✭
    edited January 2019
    check your mail.
  • Member ✭✭
    edited January 2019
    No luck so far, will re-check in the morning
  • Member ✭✭
    edited February 2019
    I would actually love to see something like this integrated into future versions, seems to be a demand for it. Just my 2 cents.
  • Member ✭✭
    Still did not receive the email with the v1.6 .  Perhaps the exe file was being blocked. :-(
  • Member ✭✭
    I sent a copy as a Google Drive attachment to avoid the goofy email attachment blocking.
    Larry, W1IZZ
  • Member ✭✭
    Larry, Any chance you could spare another copy?  Thanks!
    Pat Eastman  K7PWE
  • Member ✭✭
    edited June 2020
    Ed, I have the latest which is the one that displays the frequency. Send me your email and I'll send you the file.
  • Member ✭✭
    Email address?
  • Member ✭✭
    Same version I have--1.6, which displays freq.
  • Member ✭✭
    patricke@peak.org
    Thank you!!
  • Member ✭✭
    I would like to get the latest version also. The one I have doesn't display frequency. w6caw@craigwilliams.com
  • Member ✭✭
    Larry,
    Thanks... got it this morning.
    Ed W2PH
  • Member ✭✭✭
    I thought I had 1.6 but I do not, I have Smart S-Meter PLUS version 1.0.0 and it displays the frequency, works fine, but could someone send me 1.6? Once I get it is there a problem if I provide a downloadable public link to this on my website?
    If not that's ok, I'll keep it private.
  • Member ✭✭
    Question. Is this "freeware" or not?
  • Member ✭✭✭
    yes, that is what was listed on the website when it was still active, this was freeware.
  • Member
    Can you email me a copy also? I would like to try it with my 6700. Thank you.
  • Member ✭✭
  • Member
    Craig
    Thank you.
    Tim
  • Member
    I tried Craig's version and it is 1.0
    Can someone provide a link or email a copy of version 1.6?
    Thank you in advance.
  • Member ✭✭✭
    See if this google drive link works. This is v 1.6 of the S-Meter.
    https://drive.google.com/drive/folders/1gEnWd6DVmrtgfEk3dQqE4OY1iTe9ff2Y?usp=sharing
  • Member
    Link worked great. Craig's V1 has slight differences than the v1.6. Choose the one you want to use. I will play with both. Thank you.
  • Member ✭✭✭
    let me know if this worked or not, first time using google drive.
  • Member ✭✭✭
    edited April 2019
    I downloaded from Larry's google drive and the file that says it's 1.6 seems to be the same as 1.0. In fact the release notes of both say "Rel. 1.0.0 - start release."  So I may have had 1.6 all along.
  • Member ✭✭
    I should point out that 4 different virus checkers think the above file has been infected with possible ransomware.  But far more think it is clean.   What virus software is running on the system where you uploaded it to dropbox?
    You can check the file by uploading to https://www.virustotal.com
    It is possible it's a false positive, or not?
    Neal
  • Member ✭✭✭
    edited April 2019
    V 1.6 allows multiple instances of the S-meter, other wise I think it looks the same. I wonder if in the future this could be launched by sliceMaster per open slice.
  • Member ✭✭✭
    Was a long tmie ago I downloaded it and running 4 meters so I must have had v1.6 all along. Thanks for the clarification
  • Member ✭✭
    The one on my website has the slice frequency shown. It looks like that is later than v1.6? I also just put up the very early version 1.2
     SmartSmeter Plus
  • Member ✭✭
    Hard to say.  As good a job as the authors did for making these meters work for Flex,
    they did an inverse fantastically bad job at version labeling.   I just installed both, the one from Larry and the one from Craig.
    On the setup screen, they both claim to be version 1.0.0.  But the one with the VFO sub-display has a window title bar calling it Smart S-Meter PLUS, and the one without
    the VFO display has a title bar of V16.   So, is PLUS newer or is Ver 16 newer :-)
    You decide :-)    How can these guys be SO good at programming and SO BAD at versioning.
        Ing-ah-neeers.  Every where ya' go...
    [Neal shakes his head....]
