S Meter Plus
Ed Johnson
Does anybody have a current versio of Beppo's S Meter Plus? Woodbox radio is long gone.
I have the woodbox smart s meter v16 if that does you any good.0
Larry,
Yes, I have the original version but was hoping to upgrade. Is it email-able? ed@w2ph.com
Thanks0 -
check your mail.0
No luck so far, will re-check in the morning0
I would actually love to see something like this integrated into future versions, seems to be a demand for it. Just my 2 cents.1
Still did not receive the email with the v1.6 . Perhaps the exe file was being blocked. :-(0
I sent a copy as a Google Drive attachment to avoid the goofy email attachment blocking.
Larry, W1IZZ
Larry, Any chance you could spare another copy? Thanks!
Pat Eastman K7PWE
Ed, I have the latest which is the one that displays the frequency. Send me your email and I'll send you the file.1
Email address?0
Same version I have--1.6, which displays freq.0
patricke@peak.org
Thank you!!
I would like to get the latest version also. The one I have doesn't display frequency. w6caw@craigwilliams.com0
Larry,
Thanks... got it this morning.
Ed W2PH0 -
I thought I had 1.6 but I do not, I have Smart S-Meter PLUS version 1.0.0 and it displays the frequency, works fine, but could someone send me 1.6? Once I get it is there a problem if I provide a downloadable public link to this on my website?
If not that's ok, I'll keep it private.0 -
Question. Is this "freeware" or not?0
yes, that is what was listed on the website when it was still active, this was freeware.
Can you email me a copy also? I would like to try it with my 6700. Thank you.0
I put it on my website at: http://www.craigwilliams.com/radio/flex3000/index.html0
Craig
Thank you.
Tim
I tried Craig's version and it is 1.0
Can someone provide a link or email a copy of version 1.6?
Thank you in advance.
See if this google drive link works. This is v 1.6 of the S-Meter.
https://drive.google.com/drive/folders/1gEnWd6DVmrtgfEk3dQqE4OY1iTe9ff2Y?usp=sharing
Link worked great. Craig's V1 has slight differences than the v1.6. Choose the one you want to use. I will play with both. Thank you.
let me know if this worked or not, first time using google drive.0
I downloaded from Larry's google drive and the file that says it's 1.6 seems to be the same as 1.0. In fact the release notes of both say "Rel. 1.0.0 - start release." So I may have had 1.6 all along.
I should point out that 4 different virus checkers think the above file has been infected with possible ransomware. But far more think it is clean. What virus software is running on the system where you uploaded it to dropbox?
You can check the file by uploading to https://www.virustotal.com
It is possible it's a false positive, or not?
Neal0 -
V 1.6 allows multiple instances of the S-meter, other wise I think it looks the same. I wonder if in the future this could be launched by sliceMaster per open slice.0
Was a long tmie ago I downloaded it and running 4 meters so I must have had v1.6 all along. Thanks for the clarification
The one on my website has the slice frequency shown. It looks like that is later than v1.6? I also just put up the very early version 1.2
SmartSmeter Plus
Hard to say. As good a job as the authors did for making these meters work for Flex,
they did an inverse fantastically bad job at version labeling. I just installed both, the one from Larry and the one from Craig.
On the setup screen, they both claim to be version 1.0.0. But the one with the VFO sub-display has a window title bar calling it Smart S-Meter PLUS, and the one without
the VFO display has a title bar of V16. So, is PLUS newer or is Ver 16 newer :-)
You decide :-) How can these guys be SO good at programming and SO BAD at versioning.
Ing-ah-neeers. Every where ya' go...
[Neal shakes his head....]0
- 314 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 242 SmartSDR CAT
- 174 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 118 FLEX-8000 Signature Series
- 855 Maestro
- 44 FlexControl
- 804 Genius Products
- 279 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 408 Remote Operation (SmartLink)
- 132 Contesting
- 639 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 878 Third-Party Software
