Hamation Bandpasser AS-419
Is anyone using the Hamation Bandpasser AS-419 filter with their Flex Radios?  The documentation is a somewhat confusing.  I am reading that you have to raise 12vdc to the pin on the remote input to switch bands.   I don't see how this can work if the FTDI USB to parallel interface only supply's 3.3vdc.
thanks.
Welcome!
  • Member ✭✭
    edited January 2019
    I found a level shifter that can be used if the AS-419 requires a 12vdc input.
    https://www.tindie.com/products/ddebeer/12-channel-level-shifter-and-buffer/#product-description
  • Member ✭✭
    edited February 2020
    Update - We purchased the Bandpasser and realized that BCD can also be used to control the unit.  Took about 5 minutes to configure and it works with no issues.
  • Member ✭✭
    Hi Mike, can you use BCD right into the bandpasser from the USB cable ?
  • Member ✭✭
    edited February 2019
    Yes that is what we do.  Here are screen shots of the config.
    Hope this helps.
  • Member ✭✭
    Please supply the wiring color code to the mouser cam shell FTDI USB unit. I can't get the correct wiring code to make the AS-419 to work.
    Thx
  • Member ✭✭
    Mapping for AS-419 BCD DB-15 port
    Grey  = A
    Purple = B
    White = C
    Blue = D
    Black = Ground
  • Member ✭✭
    Mike, your the man, Thx..
    When you have the letters, I have numbers on my FTDI USB unit cam shell that I **** the colored wires into. Would A=1 , B=2?
    Plus its a DB-9 for the AS-419
    Thx
  • Member
    David - Did you get answer to the pin mapping? I'm looking for the same thing. Andy NA4DA
