FlexAPI V2 based SmartLink WPF Client Sample
I have created a sample WFP C# project that shows how to connect to a FlexRadio V2 via SmartLink.
https://github.com/mkcmsoftware/smartlink_v2
2
Mark,
I cannot seem to resolve Auth0.Window0 -
Nice job Mark. I got Smartlink working via command line a while back just for fun, although it does show a gui pop-up for the auth part. In case anyone is interested.
https://github.com/rfoust/FlexModule
The code around Smartlink is here:
https://github.com/rfoust/FlexModule/blob/master/Public/Connect-FlexSmartLink.ps1
-Robbie
Auth0.Windows is obtained from the SmartSDR installation folder.
Make sure your reference for this DLL is correct in VisualStudio.0 -
Thanks. Didn't think to look for it there.0
find . -name Autho.Windows* 2>/dev/null
Can this project be compiled / linked / run on Mono?
https://www.mono-project.com/
k3Tim0 -
Thanks Mark,
If anyone is interested in a macOS solution, please take a look at my GitHub page:
https://github.com/DougPA/xLib6000
The code for doing SmartLink is contained in this project (although not broken out neatly as Mark has done). This code was developed by Mario Illgen, DL3LSM along with some help from Flex and Don Agro of dogparkSDR.
Look in the WanServer.swift file. This project is a Mac-centric replacement for FlexLIb. The code is used by a SmartSDR-like client. That project is located at:
https://github.com/DougPA/xSDR6000
In that project, look at the WanRadioPickerViewController.swift file. It uses the xLIb6000 WanServer to enable SmartLink connections.1 -
Mark,
Any chance you have the code for that github repo? The link appears to be dead.
John0 -
try again0
Awesome! Thanks very much!0
I have a new repo underway for my FlexLIb-like Mac solution, it's now at https://github.com/K3TZR/xLib6000.
The SmartSdr-like client is also now at https://github.com/K3TZR/xSDR6000.
While you're there, please look at https://github.com/K3TZR/xAPITester , it allows you to explore the FlexLIb API and test commands.
73's Doug0
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
