N1MM CW MOX PROBLEM
Richard Zalewski
Setting up my first Flex (6600M). In N1MM+ CW after I key a memory F button it goes back to receive but for less than 1 second and then the MOX button lights up and no receive.
Check the N1MM+ macro to make sure it's not "unkeying" at the end of the string. Your 6600 should be running QSK which means you should need no TX or RX commands. I think . . . I'm still learning N1MM+ after years on WriteLog.0
Thanks for reply but no TX or RX commands in the macros. When I key with paddle no problem. It drops back to receive immediately. Got it...N1MM config problem....now just have to figure why I cant change bands with n1mm0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 171 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 248 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 191 FLEX-8000 Signature Series
- 913 Maestro
- 887 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 742 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 955 Third-Party Software
