Maestro loading error 152 with Maestro Hardware also lights flickering on Maestro
Jerry WA9UKB
Maestro loading error 152 with Maestro Hardware Please Try Again (W, X, Y, Z, K
tried rebooting several times also Maestro Lights are flickering Is their anything I can do to correct this?
Jerry, WA9UKB
https://community.flexradio.com/flexradio/topics/maestro-loading-error-152-with-maestro-hardware-also-lights-flickering-on-maestro/edit
Jerry, WA9UKB
Jerry,
I'm pretty sure I know the issue but you should open a help desk ticket with FlexRadio.
Mack
W4AX
Alpha Team0 -
Found issue, 110 Volt Power cord to 12 Volt Power supply that came with Maestro was open on hot side of plug, Replaced Power Cable and restarted Maestro. Back up and running.
Jerry,
I'm pleased you sorted things out. It's almost always a power issue or a cable that is disconnected to that board inside the Maestro.
Mack
W4AX0 -
Yes, you get this when the batteries are low or dead (the external one and the internal one).
[{"insert":"I had the same problem. My wall wart turned out to be kaput. Maybe in addition to a cryptic error code there should be a notice of possible power issue to the Maestro? Then again that would make too much sense. I've found that code writers don't always use common sense.\n"}]1
I pick up a maestro A it had been setting around for 3 years went to hook it up did not power up. Replaced the battery in the Dell tablet and WOW it powered up then down loaded the latest software in both the maestro and the 6500 then got a loading error 152 with maestro hardware. Looked at the other posts and seen it may be a power problem so i removed the dell tablet and then used DeoxIT on all the plugs going in to the tablet and the main board in the Maestro and low and behold it worked great up and running great. So if you are replacing the battery in the tablet i would Deox all the plugs it the maestro worked for me may work for you.
Thanks 73's
KD8NNI
Mike1
- 376 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
