my new 6400m will not change ant ports stuck on number 1 ? !? all tx is from port 1, screen shows
wayne mckenzie
my new 6400m will not change ant ports stuck on number 1 ? what have i done wrong !? all tx is from port 1, screen shows ant 2 for tx but rf comes from port1
Review the profiles section of the manual antenna ports are persistance and profile related also by band so without added info provided you need to do some reading, however you also need to make sure you have a dummy load on both ports and be sure your power is set to less than 10 watts till you figure out how to operate your rig to prevent damage which if done by the user is not covered under warranty due to mis operation.0
Wayne, Make sure you are changing the RED, TX , in the Slice window. Change the TX antenna there, also make sure the Slice is unlocked.0
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
