Flex 6700 shutting down
Johan _ SE3X
Anyone seen this error message and knows what it might be that causes it? Before i start ripping everything apart here to check the internal fuse I was cuorious if anyone had any idéa in what direction I should be looking? No warranty, so would be nice to know if it's a possibel DIY job or something worse.
Took a quick look in the manuals and made a search here, but couldn't find any list of error codes.Maybe have to open a ticket? but start by asking the community.
Tighten your power cables and try a different power supply first. If that doesn't fix it, it's probably the fuse as indicated, or it may require a trip for service.
And while you're in there, **** those dust bunnies out!0 -
Hi Ria
Tnx for your comment. I found a similar question, not 100% identical, but close. https://community.flexradio.com/flexradio/topics/flex-6500-error-message-check-fuse
I have planned to replace my old PS anyway. Maybe this was a sign from above ...
Hi Johan,
Several of us have seen this issue. In my case it was a dirty fuse. Details here:
https://groups.io/g/FlexRadioSmartSDR/topic/6700_low_voltage_lockup/29112663?p=,,,50,0,0,0::recentpo...
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Tnx Al and Ria!
Plan is to take the Trx apart for "maintenace" anyway. Probably loads of dust inside .. Been hoping to receive new fans soon, if I should need to replace them.
I'l take it to the workbench asap then. As it sounds, I don't need to loose to much sleep over it.1
- 112 SmartSDR+
- 944 Maestro
