IMD Testing Flex 6400
Ed Johnson
Is it possible to do IMD two tone test using an audio file and DAX? I am looking to do this with a 2m transverter and a spectrum analyzer at several RF power levels
Yes, I have used Audacity (a free Windows application) to generate a two-tone signal and send it to SmartSDR via DAX. Works well.
Doug K4DSP
I use my Rohde&Schwarz HF signal generator and my spectrum analyzer using the methods mentioned here: www.ab4oj.com/sdr/flex/6700notes.pdf
The test results for my Flex 6500 are very similar.
Testing a VLF converter for SAQ Alexanderson (example)
Alex, I believe you are talking about two-tone IMD3 dynamic range testing of the receiver. I believe Ed is referring to TX IMD testing which requires an audio signal generator, not an RF signal generator.
If I am wrong, please let me know.
Doug K4DSP
P.S. The R&S test equipment is very nice. I did some work for R&S in Munich back in the 1990s. Bavaria is a lovely place.
I lived by Ostbahnhof in Munich for eight years starting in the late 90s. I always wondered what it was like to work at R&S, which is walking distance from there.
Doug,
Yes, I am talking about two tone Tx test for transmit IMD.
Ed W2PH1 -
Thank you for clarifying, that it's a transmit IMD test. Good idea to use Audacity to try this. I've always used NF tone generators and will try an audio file now :-)
73, Alex - DH2ID0
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
