6400 not selecting bands
6400 will not select 17m or 15m when using the maestro or the iPad.
Works OK if selecting via MacLogger DX on the MAC
Fault is obviously in the transceiver.
Welcome!
  • Member ✭✭✭
    edited March 2019
    Phil,
    I recommend the following steps.
    1. Export your profiles.
    2. Restart your 6400 and hold down the power key for about 5 seconds when powering on to reset the radio.
    3. Import your profiles but UNCHECK Preferences. (shown highligted)
    Mack
    W4AX
    Alpha Team
  • Member ✭✭
    edited January 2019
    Sorted  !
    But why did it get into this state ? Is this to be a common occurrence ?
    Just got the Flex setup a couple of weeks ago - I have been looking at them for some time - been running a full K3 station since they first came out - 6400 and Maestro is certainly an interesting radio
    Phil G4UDU
  • Member ✭✭✭
    edited March 2019
    Phil,
    I can't say why this occurred but this has never happened to me and I've been running Flex radios since the very first pre-production models.
    Chalk it up to a Gremlin somewhere. If you follow the K3 reflector all radios have an occasional issue.
    Mack
    W4AX
