Smartcat won't load
Mark Erbaugh
Mark Erbaugh Member ✭✭
edited February 2020 in SmartSDR CAT
SmartCAT v2.4.9 won't load. I have uninstalled and reinstalled SmartSDR v2.4.9 numerous times. I have eliminated all other virtual serial port driver from my system. I'm pretty sure they are all gone and the drivers are cleaned up and removed. There are no ghosted serial ports on my system. I even went into the UEFI and uninstalled my real hardware serial port (COM1).
When I try to run the REPAIR option on the FlexVSP installer, it says it is only for installed programs.
SmartSDR seems to be working fine.
  • Mark Erbaugh
    An update:
    I installed the exact same download file on another PC. It went off without a hitch and worked. During the installation, I noticed a popup about configuring FlexVSP, which I did not see in all my installs on the original computer.
    In the Program FilesFlex Radio SystemsFlexVSP there is an installer. I ran that and now SmartCAT seems to work. Somehow the main installer was skipping that, even though it installed an Icon for SmartCAT on my desktop.
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited January 2019
    Yes, I had that problem with the first Win10 1809 update. Tim helped me with it but I am still using v 2.3.9 The latest update seems to be working.
