Flex 3000 Problem
Burt
Member ✭
Flex 3000: Blue Light on saying the radio is powered on. Green Light on back of the radio is lit saying the computer is talking with the radio via the Fire Wire. I click on SDR 2.7.2 icon I get "Available Radio Interfaces" screen. Demo slot is shaded indicating it is the only one available. Slot for my radio is not shaded indicating it is not available. That screen is as far as I can go. What is wrong?
Did your check the connection between computer and the 3000 ?1
Power down power sdr..and the 3000..asuming this is first time connect of computer to 3000 then you should see the setup connection between each onscreen as loading eprom to the 3000 and pc..this takes a few minutes...frist though with 3000 powered down...open powersdr ..u should see demo mode onscreen...then power up the 3000...wait till the two see each other this will show as eprom loading and both devices connect...when this completes you will see your 3000 show below the demo indicator as your 3000's serial number...once this is done you can then switch powersdr on...the two should be shaking hands so to speak..if you see action on any and all bands then its working...also you need to install V.A.C. ..4.8 ontoyour computer..thats virtual audio connector...this makes things a bit more able to work...connect a powered audio amplifier to the 3.5mm audio connection on the 3000..2 to 5 watts is fine..in settings on powersdr you set audio to the VAC.. you yse this as your addio rather than your sound card on your pc...if you have a copy of the manual for the 3000 study it and things will be even more clear than ive described here..once youve got everything going on the pc and radio im sure you will be impressed with the 3000 and its workings..even yhough its not made anymore its still relevant..regards francis..ei3gqb..0
NVM. Misread your post.
Sorry Francis for not responding sooner. I tried all of your suggestions. Nothing works. I am beginning to think problem is with the radio. I have also tried the 2.8 version by KE9NS.
Burt AF5AA0 -
Could be firewire chip in the 3000 burt..my 3000 was a gift from a friend...had the same problem..so he told me to send it to the flex repair center in germany..i did.. it had 3 components replaced..the firewire chip the overload protection chip and a rf choke..costing €18..total cost was €198..for testing and 2.5 hours on the test bench..which my buddy paid for..got the radio back from germany with the invoice..and payment was not needed in advance..got it checked out the 3000 for 2 days before my friend bankwired the fee to the flex eu repairshop...all in all a vgood customer experience..find out the nearest flex repair shop to and include a simple writen review of the ploblem in your package that gives them the heads up of what to look for..hope you get the 3000 sorted and back in working order..great radio when everything comes working..regards francis0
Hi Burt,
Would you please let me know on how to contact the repair center in Germany? as when I request the repair of my 'Flex3000, I'm always redirected to the USA, germany is much closer to me, I reside in the UK. Thanks Burt.0 -
Flexradio repair service Germany: Norbert Wrede, DC6UW FlexRadio Systems Service Center EU Habyer Str. 22 24361 Gross Wittensee Tel.: (04356) 1625 E-Mail service-eu@flex-radio.com1
Many thanks Alex, much appreciated!!!0
- 325 Community Topics
- 590 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 394 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 150 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 274 Shack Infrastructure
- 194 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 135 Amateur Radio Interests
- 938 Third-Party Software
