WSJT-X Advantages of Setting up multiple instances each with unique panadapters and Slice?
Jerry NY2KW
I have read several posts that recommend setting up WSJT with a different configuration file for each band where each configuration has its own panadapter and unique slice? What are the major advantages of this - seems a bit complex and not obvious whats to gain. I have been using WSJT-X on my 6700 for a few months and changing bands seems a breeze using the band dropdown box in WSJT-X and my 6700 remains in DIGU with all the settings staying the same. I must be missing something bigger but as a WSJT-X newbie it is not obvious. Can anyone help explain?
I guess if you're into watching lots of bands at the same time this might be useful, but then you'll have to have multiple instances of WSJT-X open and running at the same time as well, I'd think. One band at a time is fine wtih me. Now if I could only find a way to force it to call DIGI-U mode instead of USB I'd like that better. l0
One example benefit is visually seeing, at the end of the day. When people migrate from 20 to 40m.0
Another use for me having a dual SCU radio you can run one antenna to once slice and another antenna to a second slice. I used this to monitor propagation as the antennas have different angles of radiation. So have two slices on the same band can net you different DX.
I typically run two bands simultaneously on my 6700 and may monitor up to 5 bands.. When running 2 bands, I have each on a different antenna... and can run alternating Q's at the same time.0 -
I usually monitor 2 to 4 bands at the same time. I use JTAlert-X as well. This allows me to downsize the WSJT-X screens, keep the JTAlert-X windows at the bottom of the screen and do other things on my computer while listening for an audio alert from JTAlert-X for needed states, zones and DXCC.
I usually watch a movie or listen to music while playing 3 minute chess games as JTAlert-X does the band monitoring for me. I like to multi task
Hi Duane, mine auto changes to DIGU I think what I did in
WSJT was to go to File, Settings, Radio, then under MODE select up "Data/Pkt".
YMMV
73's
Bret
WX7Y
Thanks, Bret - I'll check on doing that. Appreciate the assist!0
I only have one antenna right now but would like to monitor WSJTX on 80m, 40 and 20 simultaneously, Should I use 3 slices in same panadapter, each with its own DAX channel or should I use 3 separate panadapters?0
Hi Jerry,
I was a little bored recently and launched two synchronized instances of WSJT-X in FT8 mode on my Flex 6600 to compare two antennas.
One SCU was connected to a SteppIR elevated vertical (Slice
and the other to a home-brew hex beam (Slice A) at 30 feet and 270 degree azimuth. I configured both panadapters scales exactly the same and then synchronized decoding within a second (erase, decode) and when the RX cycle ended I grabbed a screen shot. Note that the first decoded call sign is same for each instance of WSJT-X.
It was an interesting experiment, yielding mostly expected, but useful insight into the relative performance of the antennas.
The screen shot below was extracted from a 43" 4K TCL HDTV, although I'm not sure it will enlarge to legible size.
Larry KB1VFU
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 94 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
