6500 Network Connection drops
Steve Belcak
All of a sudden I'm loosing my network connection.....Rig 6500 PC Intel NUC i7 500g 16G Mem SSDR 1.11.12.446 Win 10 Pro Ver 1809 Build 7763.195 I timed the drop outs and out of 5 connects, I lost the connection at the 10 minute mark....PC is only a month old, been looking for power settings for the ethernet adapter and can't find anything in windows.... I'm not loosing the ethernet connection to the pc or rest of network....everything goes to a Unifi Switch then router to outside world....tried both Static and DHCP....same problem....would appreciate ideas on how to approach looking for the problem.
Try removing power from the radio for a few seconds and, then, bring it back on line.0 -
You should find the power and sleep menus in the Win10 "Settings" page. If momentarily removing the 12 volts from the radio doesnt work. Connect the NUC directly to the 6500, bypassing the switch and router. That should narrow the problem to either the NUC or the radio.0
Thank you Jim and Gayle.....looks like removing power has solved the problem. Radio has been running for almost 1 hour and no problems. 731
Great, glad it s working.
Gayle0
- 112 SmartSDR+
- 944 Maestro
