I removed SSDR form a lop top I want to use with PSDR and cant remove DAX audio files in Device Man
Tom Koch
I have previouslay installed Smaart SDR on a laapto[t that I now want to use with Power SDR to use with a Flex 1500 and virtual audio connection but cant get DAX removed from my audio devices.
When you were un installing SSDR did you select yes to remove all DAX0
You DON'T need to remove SmartSDR if your also running a Legacy Flex5000, 3000, 1500.
The one program has nothing to do with the other as far as the computer is concerned.
I run PowerSDR for my Flex1500 and SmartSDR on the F6700 and F6600 on the same machine all the time.
Bret
WX7Y
When you uninstall SmartSDR, THE question asks “ Do you want to keep the DAX Drivers?” The correct answer to remove is. “NO”. Once uninstall is complete, then reboot for Windows to reset sound drivers, there should not be any DAX drivers in the Windows Drivers or in the Window Sound Properties. Hope this helps. 73 Dudley1
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
