DAX doesn't communicate with the sound card
Are meaning when you click the REMOTE button on the SSDR or are you trying to send audio to the third party program? If you mean the REMOTE button so the SSDR audio is heard on the PC check what the Windows default audio device is set to. When SSDR is install it makes one of the DAX devices the default instead of your actual speakers.
when I click on REMOTE I hear the sound in the speakers.
Here my screen shot
With WSJT-X I have the same problem !
That is in the setup of the WSJT where you will configure one of the DAX RX slice to be use.
I think you want the Entree setting to be a microphone that is available on the PC.
It's the same with DM780 from HRD.
No that's work before and now it don't work but why ?
Despite I have erase everything and reinstall. I just noticed also that DAX iQ does not work (driver error) !
This may be easier done with a Teamviewer session if you would to try. I sent you an email.
No problem David
It looks to me like at least part of the problem is that your DAX device is set as the default audio device. That can cause problems. To address this, right click on the speaker in the taskbar and select Sounds. Make sure that your built in soundcard (typically called Realtek, Nvidia, etc) is set as the default device on both the playback and recording side to mitigate this issue. Right click on the audio device and select Set as Default Device to change it.0
here is Eric
it seems to me that I should have small bars indicating the sound?
Check to make sure your DAX audio inputs and outputs look like this....
We worked through his issues. Involved some cleanup, the manual driver reinstall, and resetting the windows default sound devices. It seems to be good now.
https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
hi,
yes it' seems to be good about DAX on Flex radio but I don't have communication DATA between Dax Audio and sound of PC !
Can you provide more details on what is not working? If I understand correctly you have audio from the radio when you select the REMOTE button in SSDR, the DAX pannel show all active options in blue. What program(s) are you trying to use and configure?
Here it is repaired. In fact it was necessary found that the Settings -> Privacy -> Microphone -> Allow apps to access my microphone was disabled!
I could not have done it without a lot of support from Eric KE5DTO and David N2MHI.
- 369 Community Topics
- 628 The Flea Market
- 85 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
