DAX doesn't communicate with the sound card
ON5AM
ON5AM Member ✭✭
edited December 2018 in DAX
Hi,
Here is the problem: I don't have a reception in the PC (see capture) yet the flex works because he listens. But the sound doesn't arrive in the PC (that's what I think)
Can you help me ?
  • David
    David Member ✭✭
    Are meaning when you  click the REMOTE button on the SSDR or are you trying to send audio to the third party program? If you mean the REMOTE button so the SSDR audio is heard on the PC check what the Windows default audio device is set to. When SSDR is install it makes one of the DAX devices the default instead of your actual speakers.
  • ON5AM
    ON5AM Member ✭✭
    when I click on REMOTE I hear the sound in the speakers.
    Here my screen shot
  • ON5AM
    ON5AM Member ✭✭
    With WSJT-X I have the same problem !
  • David
    David Member ✭✭
    That is in the setup of the WSJT where you will configure one of the DAX RX slice to be use.
    I think you want the Entree setting to be a microphone that is available on the PC.
  • ON5AM
    ON5AM Member ✭✭
    It's the same with DM780 from HRD.
    No that's work before and now it don't work but why ?
    Despite I have erase everything and reinstall. I just noticed also that DAX iQ does not work (driver error) !
  • David
    David Member ✭✭
    This may be easier done with a Teamviewer session if you would to try. I sent you an email.
  • ON5AM
    ON5AM Member ✭✭
    No problem David
  • Eric-KE5DTO
    It looks to me like at least part of the problem is that your DAX device is set as the default audio device.  That can cause problems.  To address this, right click on the speaker in the taskbar and select Sounds.  Make sure that your built in soundcard (typically called Realtek, Nvidia, etc) is set as the default device on both the playback and recording side to mitigate this issue.  Right click on the audio device and select Set as Default Device to change it.
  • ON5AM
    ON5AM Member ✭✭
    here is Eric
    it seems to me that I should have small bars indicating the sound?
  • Terry K8EET
    Terry K8EET Member ✭✭
    Check to make sure your DAX audio inputs and outputs look like this....
  • David
    David Member ✭✭
    We worked through his issues. Involved some cleanup, the manual driver reinstall, and resetting the windows default sound devices. It seems to be good now.
    https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
  • ON5AM
    ON5AM Member ✭✭
    hi,
    yes it' seems to be good about DAX on Flex radio but I don't have communication DATA between Dax Audio and sound of PC !
  • David
    David Member ✭✭
    Can you provide more details on what is not working? If I understand correctly you have audio from the radio when you select the REMOTE button in SSDR, the DAX pannel show all active options in blue. What program(s) are you trying to use and configure?
  • ON5AM
    ON5AM Member ✭✭
    Here it is repaired. In fact it was necessary found that the Settings -> Privacy -> Microphone -> Allow apps to access my microphone was disabled!
    I could not have done it without a lot of support from Eric KE5DTO and David N2MHI.
