Heil GM 5 Mic
W2ECK
- So just got the adapter cable to hook up my Heil Goldline GM 5 mic to the 6600. Just wondering what the correct choice is for MIC in the Phone Transmit Control Panel.
- HM-Pro, Pro Set HC-6 or something else ? And the Input source is balanced ?
- Anyone else using similar mic be interested in how your setup Equalizer for your Heil mic?
- 73 Paul
Set it up, get online comments , then add your own Mike profile. Name it your mike make, model. That’s what I did with my heil HM-12.0
I used the Heil 781 profile to start with on the GM-5 microphone, and modified it for my voice. I get excellent reports on my audio. Gene, K1GD0
OK now I'm home. Here are the settings I am using for my Goldline GM-5 microphone on my 6500.
63Hz = 0
125Hz = -6
250 Hz = -8
500 Hz = -4
1KHz = 0
2KHz = 4
4KHz = 6
8KHz = 4
These seem to work very well, and I get excellent audio reports. My brother, WA6AQL, tells me my audio is just like talking on the phone, very natural.
Gene, K1GD2 -
One more thing, I use the Wide setting on the mike.
Gene0 -
Gene - tnx for sharing your setup info, very helpful. A few followup questions:
- Not sure what you mean by using the "Wide" settings?
- In the Settings-Radio Setup-Phone CW--- do you have the 20db preamp enabled? Bias on ?
- In the Voice Mode Control Panel - what settings do you have in the TX Filter- Low Cut and High Cut ??
Paul
w2eck0 -
Hi Paul,
I am referring to the Wide/Narrow switch on the GM-5.
The +20db refers to using a powered microphone such as used by Icom. I do have this enabled, as it was that way when I got the 6500 3 weeks ago, but it is not used with the GM-5. I should probably disable it.
I have Low Cut = 100, and High Cut = 2900.
I also have the GM-5 plugged into the Balanced Microphone connector on the back of the 6500, you have to select that (R-Bal) if you are using a Maestro, which I use, probably the same if using a PC.
I hope this helps. I will have to look for you on the air, where do you hang out? I'm mostly on 20 & 40 lately.
Gene, K1GD1 -
Gene
- OK on "Wide" I was searching high and low in SSDR for a wide setting- din't think about the Mic itself.
On the +20db setting, in the SSDR Manual on page 153 it says
"+20dB button: Clicking this button will enable the +20 dB gain microphone preamp.
Note: The +20 dB microphone preamp option should always be enabled whenever a microphone is directly connected the FLEX-6000. This option is not available when LINE is selected as the audio input"
-- seems like it's saying leaving it enabled??
- I don;t really hang out anyplace special but we could set up a Sked some time
73 Paul w2eck0
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
