No Dax
You can try deleting C:Users[your user directory]AppDataRoamingFlexRadio SystemsDAX.settings and have it created fresh the next time you start DAX.
The more aggressive option is to uninstall all Flex software and have the files removed with the prompt is displayed. Reboot. Then install clean. This is the process I have followed after every major Windows update release. Everyone has their own approach I just have found it to be the fastest way to get back and running.
thanks David,
Perfect, I found the main but now I still have no DAX IQ?
Look
How to recover?
Try Tim's instructions from the link Danny posted above.
I installed version 1.5!
I found after several tests the DAX-IQ but I still don't have a DAX TX?
In "How to Manually Re-Install DAX Drivers" I see 'BATCH files' & 'drivers' but where are it?
You should be able to find in the directies in the path below. W
C:Program FilesFlexRadio SystemsSmartSDR v[your installed version]64-bit Drivers
pff... nothing below!
The path you show does not look like the standard installed path. What do you show for directories in the FlexRadio Systems directory?
dir C:Program FilesFlexRadio Systems
Here is :
It's good now... yesssss
I uninstall all Flex software and files. I Reboot and then install clean a new version of SmartSDR 1.11.12
Now all is perfect and I waiting Version 3 of SmartSDR
Thanks David and Danny.
- 349 Community Topics
- 614 The Flea Market
- 7.9K Software
- 2 SmartSDR+
- 6.3K SmartSDR for Windows
- 411 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 205 FLEX-8000 Signature Series
- 920 Maestro
- 893 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 138 Contesting
- 754 Peripherals & Station Integration
- 973 Third-Party Software
