No Dax
You can try deleting C:Users[your user directory]AppDataRoamingFlexRadio SystemsDAX.settings and have it created fresh the next time you start DAX.
The more aggressive option is to uninstall all Flex software and have the files removed with the prompt is displayed. Reboot. Then install clean. This is the process I have followed after every major Windows update release. Everyone has their own approach I just have found it to be the fastest way to get back and running.
thanks David,
Perfect, I found the main but now I still have no DAX IQ?
Look
How to recover?
Try Tim's instructions from the link Danny posted above.
I installed version 1.5!
I found after several tests the DAX-IQ but I still don't have a DAX TX?
In "How to Manually Re-Install DAX Drivers" I see 'BATCH files' & 'drivers' but where are it?
You should be able to find in the directies in the path below. W
C:Program FilesFlexRadio SystemsSmartSDR v[your installed version]64-bit Drivers
pff... nothing below!
The path you show does not look like the standard installed path. What do you show for directories in the FlexRadio Systems directory?
dir C:Program FilesFlexRadio Systems
Here is :
It's good now... yesssss
I uninstall all Flex software and files. I Reboot and then install clean a new version of SmartSDR 1.11.12
Now all is perfect and I waiting Version 3 of SmartSDR
Thanks David and Danny.
- 383 Community Topics
- 638 The Flea Market
- 145 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 261 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
