Mic gain issues
Joe Sartori
I do allot of FT8. And sometimes switching back to SSB even if i put the mic gain to 100 i get no or very little drive. sometimes a reboot will fix it but my 781 has been working but now I'm sure its a setting i am over looking...
Joe, do you have Mic +20dB engaged?
Lee0 -
Make seperate profiles, one for SSB and one for FT8. then when you switch just chose the profile and go3
Also make sure you have the CORRECT Mic selected, If your running the PC MIC you have to turn off DAX in the P/CW window for the PC Mic to work and back on for your digital program to work.
73's
Bret
WX7Y
yep sure do something changes in ft8 and audio path not good afterwards.. BTW Im just loaded the new 2.0 wsjt software
we need to do a document on this..!!!!
Yes, profiles makes things easy , once you have everything set up as you like it for each and all is working fine, just save the profile, that way whaen you change back and forth everything you set will be recalled and you won't forget something.
What I do is make a mic profile and a TX profile both named the same, for SSB and for digital.1 -
maybe i need to do a factory reset and then load my standard profile and save it as ssb and then a ft8 one as well..... Something is very confused besides me!!
What mic input are you using, "BAL or MIC"? I have mics on both inputs, if I select RTTY or DIGU and then select SSB, the radio automatically enables the "MIC" input when going back to SSB. If I want to use the mic connected to the "BAL" input, I have to manually change it. I use a profile to do this. Could this possibly be your problem?
Gayle K0FLY
Gayle -- this was my problem. Thanks.0
I will check when I get home....
I have been playing with the radio, the behavior of my unit has changed, it is working like I think it should. It now returns to the mic input that was enabled prior to selecting RTTY or DIGU. Maybe persistence is getting into the game.
Gayle
- 384 Community Topics
- 643 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
