DAX problem
DAX problem…Flex6500, DXLab Commander, WSJT-X all worked
perfectly until a few days ago… then
the following screen shots occurred and WSJT-X
no longer Receives signals…
Software – SDR v. 2.4.9, Windows 10 Pro with latest updates
Windows – Sound – defaults: Recording: DAX Audio RX1, Playback: Speakers/Headphones
Control Panel – Device Manager – Audio devices show the correct 28 total DAX entries and NO hidden entries…
DAX files have been removed and reinstalled multiple times without success…
SmartSDR has been completely removed and reinstalled multiple times without success…
DAX panel shows TX and RX streams working, but IQ Streams with Driver Error
WSJT-X - Settings – Radio, Test CAT and Test PTT work correctly
Help!! Could there be some residual Windows Registry fragments that are causing this?
Thanks for any advice, Mike, K6DRY
Hi Michael,
Looks like you are the victim of a Windows 10 update.
Please follow the steps in this post by Neil, K3NC. It will straighten out the DAX drivers.
https://community.flexradio.com/flexradio/topics/most-common-fix-for-dax-driver-errors-in-windows-spring-update-1803-you-can-do-this
Show me CAT shoot screen Thanks George0
The answer is in what you wrote about Windows sound defaults. DAX devices must NOT be Windows default devices. This is what produced the DAX driver error: It was being used by Windows and is not available to WSJT-X.
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 912 Maestro
- 52 FlexControl
- 855 FLEX Series (Legacy) Radios
- 876 Genius Products
- 315 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 729 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
