I have a 6500 with v 2.4.9 SmartSDR and the slice flag has the frequency blocked so i can only see
leroy
I have a 6500 with v 2.4.9 SmartSDR and the slice flag has the frequency display in the flag is blocked so i can only see 1/2 of it. Is there a way to fix this?
If you could send us a screenshot, that would go a long way to helping us help you. Does this happen consistently (e.g. if you stop/restart SSDR)? What is your configuration? How is SSDR connected to the radio (direct cable or through WiFi or remote)?
Can you try on a different PC or laptop to see if you get the same result?0
Check FRS Download area and download the offered Font - that's all
73 Chris0 -
Thank you all for your suggestions. It works on different pc. I will download font and try
Also make sure you don't have font/text scaling on. In most cases that works but I have seen video setups where it did not react so well.
- 375 Community Topics
- 105 SmartSDR+
- 427 SmartSDR for Mac
