Flex-6000 with KPA-500 FYI
Doug Hall
From time to time people ask about QSK and amplifiers on the Flex, and about suitable values for TX Delay in the radio setup. Tonight I had the 'scope hooked up and looked at the key line on my 6300 and the RF output envelope from my amp. With TX Delay set to zero I see RF output start approximately 3 mS after the keyline is asserted. The keyline goes inactive again approximately 4 mS after RF goes away completely. With the Elecraft KPA-500 there is no hot switching even with the TX Delay set to zero. The attached 'scope image shows the keyline on the top trace and the output of the amplifier on the bottom trace. This is a single 30 wpm dit. (The waveform is the same with the amp on or off, only the RF output amplitude changes.)
For amplifiers with relays in the keying circuit you will need to add the appropriate TX Delay to prevent hot switching your amp. I just wanted to point out that with the KPA-500 (which has PIN diode switching) this does not appear to be necessary. I suspect it's true of the KPA-1500 as well as it also has PIN diode switching, but I don't have one of those. (I wish!)
Doug K4DSP
P.S. The odd artifacts on the RF output envelope are due to aliasing on the digital oscilloscope. You wouldn't see that on an old fashioned analog 'scope.
Doug K4DSP
You should send that to Rob Sherwood, he is recomending to all with an Icom 7610 to set the TX delay to 15ms. with an KPA 500.0
Apples and oranges.
1. The 7610 has different keying characteristics than the 6300.
2. I'm sure Rob has a better lab and is more knowledgeable and capable than I am.
3. Setting the delay to 15 mS with a Flex certainly won't hurt anything, it's just more than I need in my particular situation.
Doug K4DSP
Does anyone know if the 6400/6600 series has the same keying characteristics? I have a 6600M with delay set to 15ms but not sure i need it with SPE>
Thanks--Bill__K5ZQ0 -
Thanks--Bill__K5ZQ0
- 654 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
