6500, Maestro, CW Skimmer V2
K8AC
New 6500 user, with Maestro, 2.4.9. Trying to get CW Skimmer V2 working properly. Have read all the posts here on the subject. The basic problem is: there appears to be no communication of the 6500 frequency to and from Skimmer. The IQ stream is working and signals are seen on Skimmer. In setting up Skimmer, I note that there is no longer a CAT tab on setup. So, it's not clear how the frequency info is passed between transceiver and Skimmer. Levels of the software here are:
Skimmer - 2.0.0.393
SDR Bridge - 1.6.4.129
DAX Control - 2.4.9.196
PC is running Win 10, 64 bit. Have read the NN4ZZ Quick Start Guide with no solution so far. Thoughts and suggestions appreciated.
Skimmer - 2.0.0.393
Have you tried using Slice Master?0
The setup for Skimmer, and SDR Bridge does use CAT to pass the freq info. So CAT has to be running but you don't have to set anything up in CAT. The connections are behind the scenes.
The freq info is passed via telnet and the telnet settings in SDR-Bridge and CW skimmer have to match. The telnet settings are noted in the guide.
Sometimes a PC reboot followed by starting the programs in this order below fixes the communications.- SSDR (and CAT and DAX)
- SDR-Bridge which will then start up CW Skimmer
- Staring up CW Skimmer by itself will sometimes result in multiple copies running and can cause confusion. Best to let SDR-Bridge start up CW Skimmer.
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
No - will look at that next. Thanks.0
I went back through everything, uninstalled the software on the PC, wiped all associated files. I read your document more closely this time and see that the only difference was I didn't wipe the files in the W2RF directory before. At any rate, this time around everything works just fine! I misunderstood the SDR-Bridge function and was starting CW Skimmer separately and that undoubtedly contributed to my confusion. The last item I had missed was to right click on the slice in SDR-Bridge and select Split. Now it works as I suspected it should. One thing that would help would be a diagram showing all the pieces/parts and what flows between them.
Anyway, thanks very much for the fast assistance. I spend 99% of my time on CW and the other 1% on FT8. The new 6500 configuration has resulted in my eliminating some hardware and a lot of cables. I'm looking forward to the low band DX season and using the new rig. 73, Floyd - K8AC
Hi Floyd, Glad you got it going. Per your suggestion, I created a diagram and sent it to Ed /W2RF to review. I’ll add it to the “quick start” guide once I get it finalized. Regards, Al / NN4ZZ0
Floyd,
The "quick start" guide for SDR-Bridge and CW Skimmer has been updated. The new version is dated 6-Dec-2018. It is accessible in a few places now and eventually Ed will update his link on QRV.COM.
The primary change is the addition of a basic data flow diagram. Ed / W2RF has reviewed the diagram and given his approval. There are some other minor changes as well.
Here is a link to my page, the new file is listed in the "QUICK LINKS" section.
http://www.nn4zz.com/FLEX6700.htm
It is also available here:
https://groups.io/g/FlexRadioSmartSDR
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com0
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
