In Digi Modes ALC in Yellow?
W2ECK
New user with question regarding ALC meter. Have noticed when getting Fldigi working that when transmitting the ALC meter is in the yellow.
- Is that OK as long as not in the red ?
- If not how does one adjust the audio drive level in digi modes in SSDR ?
Paul
w2eck
Paul
w2eck
Excellent questions. I keep mine out of the red at all times! Even the tiny slot/dash in the SDR ALC scale is out of the red. I adjust mine using DAX.
I tried the DAX Tx Gain adjustment and it seems like it was lowering the Rf power out?
Paul
w2eck0 -
That is correct, backing off the audio drive will lower output power, while also reducing distortion and splatter.
There are several points in the audio chain that can control TX audio level;
1. Windows PC audio output level:
https://www.youtube.com/watch?v=ko1A1qcqWWQ
at about 3 minutes into the video, how to set output level for a specific audio channel.
2. FLdigi Transmit Attenuator setting;
Bottom of this page; http://www.w1hkj.com/FldigiHelp/audio_adjust_page.html
3. If using WSJT-X for FT-8, the PWR output slider on the right hand side of the
program user interface screen.
Please understand that properly adjusted TX audio for a clean signal WILL result
in reduction of transmit power level, but also will avoid distortion, clipping, and
splatter across the radio band.
NOTE: Modes like JT65 and FT8 are not sensitive to small amount of ALC action,
but with phase sensitive modes like PSK, you should not let ANY ALC show
on the meter. [I have done extensive lab testing with JT & FT8 modes using
a spectrum analyzer, as well as on the air coordinated testing, and moderate
ALC on the rig meter does nothing to JT or FT8 modes. You can't say the same
for PSK modes, avoid ALC with PSK modes.]
Cheers0 -
Neal and all
thanks for the replies and help. Neal thanks for the results of you testing and the insights of ALC effects on PSK31 vs. the WSJT-X modes. I am coning from the elecraft K3 worked where you shot for 5 bars on the alc meter and if over you could adjust it down by using the mic gain knob and not have to touch the power knob. As I recall you could also adjust in the Windows Sound playback levels tab. But here we are using the DAX Tx gain adjustment..
- but still am not clear whether in FT-8 by lowering Tx gain to bring the ALC down (and thus power out) I will get the same results?
Paul
w2eck0 -
Hi Paul:
Yes. To affect your ALC meter setting (and audio gain/drive), you can adjust ANY point in
the audio output path between WSJT-X and the physical radio. This includes the audio level
slider on WSJT-X (right side of window), the MS Windows Audio Playback Level slider, the
Flex DAX TX gain slider, all of them are effectively in series. Any one, or all, will control your
audio drive level.
Cheers,
Neal1
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
