SSDR and Macro's
Sergey KN7K
Member ✭✭✭
I just finished CQ WW DX Contest in CW and while 6600+Maestro worked mostly fine I had a few issues.
The main issue is that I believe that some how by entering information to F1-F4 keys of CWX window of SSDR, prevent me to use F1-F4 N1MM CW Macro's. They just do not respond.
I tried to delete all information from CWX, but no go in N1MM. Macro's in N1MM works from F5 to F12, but no F1-F4.
I thought it could be a keyboard issue and replaced it with another one, it had the same issue.
So, I was stuck with Macro issue and was CQ-ing manually-not fun.
Could someone give me an idea how to find what holding my F1-F4 buttons?
Sergey, KN7K
Sergey, KN7K
one more thing- if i delete all information from CWX lines, when i click on F1-F4, i hear the "bip", like it looking to a memory but nothing there.
So, I am looking for the way to dissable ot purge it completely to have buttons available for other programs.
Sergey, KN7K
Sounds like it is a focus issue. If SmartSDR was the last program used then Windows will direct F commands to SmartSDR. Focus helper in SmartSDR setup should allow focus to return to N1MM after a couple of seconds. One thing to check, if you are using spots from N1MM make sure to use a port other than 12060. Also no other program should be broadcasting info on 12060. Dave wo2x0
Yes, this is a focus issue. You simply need to make sure N1MM entry window has focus before hitting F keys. I had this happen by accident a couple of times during the contest.
I have stopped placing spots on Flex panadapter because of audio pops and cracks when spots get added or updated. I just populate the N1MM band map with spots.
Joe
N3HEE0 -
Thank you guys,
I tried to dissable N1MM Focus in SSDR or to put Other.
Still Have the same issue.
Here is my settings in SSDR and N1MM.
I tried to Enable "Application Info" or "Contacts" in N1MM with no change.
The intersting thing that I can send all F1-F11 all Macros buttons by clicking on the QSO entry window of N1MM just fine, but cannot do it from the Keyboard.
Currently from Keyboard only F5, F8, F9,F10, F11 works with following setup
So, i am not sure where to dig next.
Any assistance would be highly appreciated
Sergey, KN7K0 -
anyone?0
Is it established whether it is a focus issue or not? If N1MM+ is in focus, does F1 work? 73 Andy KU7T0
Guys, it can’t be a focus issue. He has said several times now that f5 and up work fine in n1mm many times over the last days. I have no idea what it might be for the record but i think we should move focus down our list of possibilities. I will also say that n1mm tech support is top notch so you may want to bring the issue to their attention for their thoughts because it could be an issue with them. I have cwx for 1-4 and use nmm f1-f4 without issue.0
Thank you guys.
I do believe it related to a Flex as I found it few months ago after I got Flex6600 but did not have a chance to look at it in a depth.
Before Flex radio, I used FT5000 for years on the same PC with no issue.
Yes, some "F" buttons work on keyboard, some not.
F1-F4 do not work on keyboard, but in the same time ALL "F" BUTTONS WORK FROM THE SCREEN. I can use all buttons F1-F12 if I push them on QSO entry window just fine.
It seems like something have reserved F1-F4 buttons and would not let me use them from keyboard.
I may try N1MM Tech support team.
Sergey,KN7K0 -
Thank you guys,
I figured it out.
The issue with FRStack, as soon as I close it, everything works as it should.
I will have to purge all saved memories and start over.
Sergey, KN7K
- 379 Community Topics
- 631 The Flea Market
- 122 SmartSDR+
- 193 DAX
- 39 Aurora
- 262 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
