Smart SDR will not start: Has unhandled error code
Scott Marlowe
Hi all. I have been busy and have not fired up the flex 6300 in a few months. Using windows 10 on a less than 2 year old computer. I went ahead and updated smart SDR version 2 but when I try to start the program I get this message. Smart SDR will not start at all
I have uninstalled and re-installed all of the flex radio software even checking earlier versions. I cant find a solution. Any help would be appreciated.
Scott
WX4SKY
Scott
WX4SKY
Scott This is Mike from Georgia contest group. I didn’t know you had a Flex. You probably need to reinstall software as there has been a few major releases of windows 10. Untinall entire package then reinstall If you need help i can talk via phone or team viewer I am good on QRZ or in club roster Mike NN9DD0
hey Mike!! I tried that, I removed all of the flex applications and re-installed with no luck. It just keeps giving me the same error code..YUCK.0
Have you tried googling the Windows error message to see if there is a known (to someone, at least) cause for that particular error? And hopefully a cure :-(0
it sounds like you've done all the 'right' things. I would suggest opening a service ticket with the Help Desk at Flex.
Actually this seems like a .NET error. SSDR as written relies upon the .NET framework. I am not sure what version they require as a minimum but you could try downloading and installing
.NET 4.7.1 or 4.7.2
https://www.microsoft.com/en-us/download/details.aspx?id=56116
I would download and install 4.7.1 and reboot then try installing and running SSDR and see if that makes a difference.0 -
Get a copy of Revo. The free version will suffice. Then set it to uninstall all of SSDR, the DAX and CAT programs, and let it to the advanced scan. SSDR will tell you you need to reboot to finish befor you do the advanced scan. Do not reboot. After the advanced scan, delete the files that show up in bold. Then remove FlexVSP. The advance scan will show that there are no files to delete after the scan is done. Now you can reboot.
By the way - this method is not canon. I just got tired of searching for the problem every time and went scorched earth, which has always worked for me.2 -
Scott
I was unable to power up my 6300 for 4 months. I then experienced strange problems that were not repeatable. Try recharging the 6300 batteries. Procedure is same as instructions that came with the 6300 when it came out of the box new. After 6 hours of recharge, all my problems disappeared. Good luck.
Stan W8NNX
Scott,
I would definitely update your .NET Frameworks as Mark had suggested.... Then reboot , and try SmartSDR again ..
Dudley
WA5QPZ
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
