DAX IQ Error after Win 10 upgrade
Tim VE6SH
The computer at my remote site did the major Win 10 upgrade last month. I realize the upgrade was pulled by MS, but regardless it happened even though I had alto upgrade turned off. The only issue I can see is with my DAX drivers as shown in the picture. I have tried a total uninstall of SDR per the Flex tutorial, but I still get the bad install of the DAX IQ drivers. I seem to recall Dan at a Flex had a fix for this some months back after another Win upgrade. Is it as simple as editing the names of the misdescribed IQ divers? 73 Tim VE6SH
Tim
Yep.
I've been fixing the mangled IQ device names successfully, that's between 90% - 100% of the fix. Describing exactly how, and what to do in a community post, is above my paygrade though.
Once you've seen it done though it's pretty simple.
I can demonstrate how it's done in a Team Viewer session, and then let you do the editing. or do it for you, (your choice). To set up the Team Viewer session I can be found in the #Flexradio IRC channel. Use your callsign for your IRC nickname, when prompted, To connect just click the #Flexradio link in my post signature below.
I'll be visible in the channel, and if I'm at the keyboard you will get quick responses from me. However if I'm not in the shack when you join, you'll need to hang out in the channel or rejoin it periodically until you get a response.
So drop by if you need any help with the fix.For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
Thank you Jay. I may take you up on this if I run into problems. Reinaldo YV5AM steered me to the right link. https://community.flexradio.com/flexradio/topics/most-common-fix-for-dax-driver-errors-in-windows-spring-update-1803-you-can-do-this Will give you a shout if I cannot make it work. 73 Tim1
I'm considering getting a computer specifically for my home flex that is not allowed to access the internet. The true solution to Windows 10 and it's acting like a virus. I have a couple air-gapped networks where W10 works pretty well.
Note everyone that the latest W10 update, aside from thinking it needs to rename your drivers, actually deletes files from some folks computers.0 -
Michael
That current version you just referred to, was deleted from the updates when they discovered that, several weeks back. So staying fully updated is now safe. If anything about Windows 10 can be considered safe.
However, The current update does have the DAX IQ device name Mangling Bug, so we learn how to work around a bug in MS Windows, like we always have.For real-time discussions
Tim
Yes, that's the correct link, I will bookmark it now, thanks for finding it.
Jay. I corrected the names as instructed in the link, but have now ended up with duplicates of DAX IQ 1, 2,3 and 4 in Device Manager. I suspect the duplicates have to be renamed as “ Reserved” devices. Do I rename the DAX IQ devices as reserved in Sound Manager under playback or recording tabs?0
Tim
You will need to rename any/all of them that are misnamed. I was hoping to explain how to figure out which are the misnamed ones in the #Flexradio IRC Channel.For real-time discussions
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
