SmartSDR for IOS SMARTlink issues
Martin Bérubé
HI,
I have noticed 2 issues with SmartSDR for IOS when running remote via SmartLink,
App version ver: V2.6.2
Radio: FLEX-6300 v2.4.9
- There is no waterfall on the display. That changed a while ago after an upgrade.
- There is a huge latency when transmitting. I can take up to 10 sec to get an acknoledgement when pushing the PTT button.
Hi Martin, I don’t have this issue Martin. Still have a very reactive PTT action when used form my hotel using the mobile network. The waterfall is also present. I’m using an iPd Pro 12,9 2nd gen. 73 de Jeff | VA2SS1
Thanks Jeff for your comment. Maybe it is just a bad setting somewhere.
73, Martin VA2PX
You might try deleting the app and reinstalling. Sometimes some obscure setting causes a problem and it's easier to do a reinstall.
Jim, K6QE0 -
tnx! will do.
With the panadapter displayed, pull out the left tabs. Click “Disp”. At the bottom see if the “Hide Waterfall” slider is green. If it is green the waterfall will be hidden.0
Your internet connection when running remote is not robust enough sounds like, I dont think reinstalling it will do a thing because you said it works fine on your Wifi 73 Bret WX7Y0
Marin,
I would suggest to switch SmartLink from UPnP to manual mode. It requires a bit of configuration work on your router but often resolves such (and other) issues.
This and other trouble shooting tips can be found in the Manual (last Chapter "Common issues" and "SmartLink doesn't connect properly").
Please keep us posted if this helps.
Marcus, DL8MRE
- 112 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
