60 Meter LSB Frequency issue
edited October 2018 in FLEX-6000 Signature Series
I have a recently received Flex 6400M - Regarding 60 Meter operation - I am having an odd issue with the frequency that I can transmit on.  First off - Digital and CW are working as expected.  For each of the 5 channels I have to have the vfo set 100hz below the normal frequency.  IE CH 3 5.357 will not allow transmit  - I have to go to 5.356.9 in order to transmit and on ch 4 I have to go to 5.371.4 in order to xmit and so on.  this obviously put the receiving station off frequency.   this occurs no matter what bandwidth setting I am on.  typically use 2.7 -  and as mentioned above CW and DIGU work as expected.   Anyone else seen this or can confirm this.  I am all up to date on the newest release of software.  thanks Joe
Welcome!
  • Member
    edited October 2018
    Your TX BW is to wide. Try to reduce your TX BW by 100 and see if that fixes it
  • Member ✭✭
    edited October 2018
    Bingo - I was changing the receive bandwidth but still had tx at 3K -  I should have known this - maybe I did but forgot.  Welcoming myself to the Mid 50's age group.
    Thanks James !!
  • Member
    edited October 2018
    No problem, I did the same thing. Enjoy your radio!
  • Member ✭✭
    edited October 2018
    Shouldn't you be using USB?
  • Member ✭✭
    edited October 2018
    Yes!, great catch - and USB is what I should have typed. Must be the age thing again. JKB4K. Wait I mean K4JKB — 73
  • Member ✭✭
    edited October 2018
    Mid 50's, wait till you hit 70's!!! :-)
    Robert
